Question about Toshiba Gigabeat F40 40 GB MP3 Player
Replace the battery
How do you disassemble the unit to replace the battery
  • 2 more comments
  • jwe11647 Feb 03, 2009
    How do you get it apart?
    Which is the back side? I have the two ends open. One end has four screws. The other end has none.. Do I need to remove these four screws?
    I can see no lock on the device I have. I have both ends open. One end has 4 tiny screws. The other end has none. Do I have to remove these four screws to get at the battery.
    The solution given by rockfixya did not help. He must be looking at a different device. The one I have only has screws on one end as I said. However, you did refer me to a site called Gigabeat surgery which contained pictures which I believe will enable me to remove and replace the battery. Thank you.
  • 679 Answers
Replace the Battery Remove five screws: two on the side, two on the bottom and one on the back behind the lanyard hook. When that screw is removed, remove the lanyard hook insert.
Slide the metal backing down as shown in the photo. Then pull it straight up.
Unhook the ribbon connection attached to the metal backing by lifting up on the brown flap where the ribbon is connected. The ribbon will then slide out.
Pull the hard drive back as shown in the photo.
Remove two screws near the bottom of the player. One is on the bottom and one is on the right side near the battery switch.
The battery is now exposed. You can disconnect it by gently pulling on the red and black cables.
Thanks for using FixYa.
Posted on Feb 03, 2009
  • rockfixya
    rockfixya Feb 03, 2009
    Replace the Battery
    1.Remove five screws: two on the side, two on the bottom and one on the back behind the lanyard hook. When that screw is removed, remove the lanyard hook insert.
    2.Slide the metal backing down as shown in the photo. Then pull it straight up.
    3.Unhook the ribbon connection attached to the metal backing by lifting up on the brown flap where the ribbon is connected. The ribbon will then slide out.
    4.Pull the hard drive back as shown in the photo.
    5.Remove two screws near the bottom of the player. One is on the bottom and one is on the right side near the battery switch.
    6.The battery is now exposed. You can disconnect it by gently pulling on the red and black cables.
    http://www.anythingbutipod.com/archives/...
    Thanks
  • rockfixya
    Thanks for your rating.
    and
  • Toshiba Master
  • 19,396 Answers
    Genius:
  • 1,913 Answers
Check in back side 1 lock is there pull that plate then pull the battery then simply change.
  • kishor khatri
    kishor khatri Feb 03, 2009
    ya u hace to open that 4 screw .then u get it frend.
How do i replace hoveround motor?
First off, are you sure it's the motor causing the problem? Changing the motor is a major job. Basically, you have to completely disassemble the entire unit.
Remove the seat and then the batteries. To get to the drive motor, you must remove the pedestal base, and the plastic shroud that covers the base plate. Remove all screws from the top of the unit, and flip over and remove the bolts from the bottom. The control box is held in place by 2 hex screws. Label the motor wires showing their location. Remove motor and replace with new drive motor. Attach motor wires and reassemble entire unit.
Aug 31, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
My Philips 9FF2CME/37 photo frame no longer holds a battery charge. How do I access the battery so that I can replace it? What type (make/model#) battery?
the Philips 9FF2 photo frame has an internal rechargeable battery inside the photo frame. So in other words, the Philips 9FF2 photo frame needs to be disassembled for you to be able to access the battery, then make necessary replacement.
With the Philips 9FF2 photo frame turned off and remove from the charger, get a screw driver, use it to disassemble the unit to take the back cover apart in order to gain access to the internal part to get to the battery.
Remove the battery, take it to any electronics part store in your area and get a battery replacement. It is not necessary that you get a Philips battery, all you need is a battery with the same size and volt/watt.
I hope the above is clear.
Regards.
Jul 18, 2011 | Philips 9ff2 Digital Photo Frame
My Philips 9FF2 photo frame no longer holds a battery charge. How do I replace the rechargeable battery?
Good luck.
HOW TO OPEN CASE OF MS3 2000 TO REPLACE BATTERIES
The MS3-2000 was not designed to be opened. The case is glued together on the sides. It cn not be disassembled without causing damage to the case
Instead of trying to replace the batteries, I suggest that you change out the entire handle portion of the shaver called a 'lower unit'. It is very cost effective. You will find a compatible lower unit at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Oct 19, 2010 | Remington Health & Beauty
Where is the cmos battery in a toshiba m45 s165. I have looked for the red and black leads and don't see them. I really didn't want to completely disassemble until it's the last resort.
Yes silverdragon is right. I just disassembled my m45 to replace the cmos. It appears to be soldered. There are no red and black wires though. You must disassemble.
Jan 29, 2010 | Toshiba Satellite M45-S165 Notebook
Can you replace the battery of the sansa clip 2GB at home? What kind of battery do you need?
The Sansa Clip's internal rechargable battery is not user replaceable. However, if it fails within the warranty period (one year), the device can be replaced.Clip's battery is not easily replaceable however if it fails within the warranty period (one year), SanDisk will replace the device.
if you want to do it yourself you have to solder, and its difficult to reassemble it once you take it apart. check sandisk sansa clip disassembled here http://www.anythingbutipod.com/archives/2007/11/sandisk-sansa-clip-disassembled.php . hope this helps
Jan 09, 2010 | SanDisk Sansa Clip MP3 Player
Magellan 1200 RoadMate Unit no longer turns on
That means that the battery inside the Magellan must be replaced.
There is need to disassemble the unit to replace the internal battery.
May 21, 2009 | PSC Magellen SL (554030-20150-020)
Toshiba Gigabeat F40 40 GB MP3 Player Logo
102 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
