Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Connection problems Have have 2 desktop connected by ethernet and laptop wirelessly connect to router no problem. First lost connection on 1 desktop and now have lost wireless connection on laptop. Laptop will connect through ethernet connection. IP adress have disappear on both any suggestion gratefully received. Thanks Leanne
  • 24_7drains Feb 04, 2009
    Turning the route off cure the laptop connecting problem thanks. But the desktop is still not connectiing.
    Ran the Start-Run-cmd
    ipconfig came back as this:
    Ethernet adaptor Local Area Connection:
    Connection-specific DNS suffix.:
    IP Address: 192.168.0.4
    Subnetmask:255.255.255.0
    Default Gateway:192.168.0.1
    Anymore suggestions would be grateffully received. Thanks for you help so far.
    Regards Leanne
    President:
  • 1,214 Answers
Reconnect the computers as you had setup originally when everything worked.
Unplug the modem and the router. Wait about 30 secs.
Plug the modem in. Wait about 30 secs.
Plug the router in.
See if you can gain access to the internet. If not, do Start|Run|Cmd
At the window, type ipconfig, and reply back what it says.
If it works, please let me know as well, and don't forget to rate my answer.
Posted on Feb 03, 2009
  • Mark Egan Feb 04, 2009
    Reboot the desktop.
    One thing to keep in mind is, on all networking issues that worked, then all of the sudden failed, is reboot everything.
    And when you reboot, follow the path of the original signal when powering back up. Like the signal comes from the modem, to the router, to the computer. Wireless devices usually don't require it, but hard wired connected devices usually do.
    The ipconfig thing sometimes keeps you from having to reboot, although all you did was get information.
    If you had returned 169.xxx.yyy.zzz, then you could have tried "ipconfig /release" and waited for the prompt to return, then "ipconfig /renew" and wait for either an error message, or for a message similar to what you returned above to diplay. You know it's working when it returns the address of the NIC card yur working from (192.168.0.4, assigned by the router) and you router, which (unless you change it) will always be 192.168.0.1.
    Let me know if I can help further.
Why does my computer say LAN is not connected but my ethernet cable is plugged in?
1. You possibly have lost the IP address from the ISP to your router and you will need to release/ renew the IP or you have a damaged Ethernet cord ( rare) but none the less could be damaged.
2. unplug the Ethernet cord from the connection at the wall for a few seconds and then plug it back in the wall connector.
Then try your connection. Call your ISP ( internet service Provider) and check the line to see if you have proper signal to the router.
Further instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 27, 2010 | 2wire (1000-400108-001) Router
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
I can only connect to router with ethernet cable and not wirelessly on one laptop and a PC but can with another laptop
If i have understood u correctly u have 2 laptops n 1 desktop.1 laptop going online.desktop and other laptop not connecting.As u r able to connect laptop wirelessly to ur router,u have configured ur router ie created a wireless n/w with network name and password(if its secured connection).You are not able to connect may be bcos u have not scan for the network in your desktop and other laptop so scan and connect to the network .If u want me to guide through scanning steps im ready to help u.
Sep 24, 2009 | NetGear DG834G Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless Network working on laptop, lost internet on desktop.
If you disconnect the desktop from the modem, were you able to get an Internet connection in your laptop?
In order to get Internet connectivity on your desktop at the same time with the laptop, then the desktop needs to be connected to the router. It should be connected to one of the Ethernet ports at the back of the router. Since, your desktop doesn't have an Ethernet port, then you need to connect a USB to Ethernet adapter to your desktop. Then from that adapter, you will connect to it an Ethernet cable going to the router.
You may check the following models:
Linksys USB200M
Linksys USB100TX
Belkin Gigabit USB 2.0 Network Adapter(F5D5055)
D-Link DUB-E100
There are other brands that offer USB to Ethernet adapters that you can check.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
76 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
