Question about Indesit W 123 Front Load Washer
Blocked sink maybe equalls non spin or drain of washer
My kitchen sink is blocked. could this be the reason why my washing machine wont fast spin or drain? its prob obvious but i wanna make sure as i am very confused.
  • zoe_powell Feb 04, 2009
    thankyou. i managed to unblock the sink and drain washer through the filter at the bottom front of machine so tried it again and it still isnt doing it. it seems to get stuck on certain programes too. the drainage pipe goes through the the same under the sink pipes.
  • Jim London
    Jim London May 11, 2010
    Hi, where is the drain for the washer located? If it is behind the sink in the plumbing scheme or it needs the sink to vent then that is more than likely the problem.
    President:
  • 1,214 Answers
It depends on where the sink is blocked, and how the washing machine plumbing is set up.
If the sink is blocked in the p-trap under the sink, and the washing machine does not drain to that trap, then it's a separate problem.
That being said, if this is in fact the way the washing machine is plumbed, then it indicates that there is not an air gap between the washing machine hose and the drain. There must be an air gap or the washer will likely not drain, regardless of how it is plumbed to the sink or not.
Reply back with further information, or if you need clarification. But yes, the sink being plugged could be the cause of the washer problem, or may just be coincidental and not have anything to do with it.
Posted on Feb 03, 2009
  • Mark Egan Feb 04, 2009
    The washing machine drain hose MUST always have an air gap between it, and house plumbing. If it doesn't, you risk the washing machine siphoning water back into itself.
    From what your describing, I am not sure how the washer drain is connected to the sink plumbing, but it sounds like a tight connection, which would be OK, as long as there was a way for air to enter to break the siphon.
    If the washer connection is between the sink and the trap, then when the washer drains, it's very likely to back water up into the sink. Depending on the washer elevation with respect to where the drain hose connects, that water could either gravity flow or siphon back to the washer when the drain cycle stops. Not good.
    If the washer connection was/is after the trap for the sink, then water could still back up into the sink, but it's less likely, depending on how well the water flows in the piping system from that point on.
    Poor draining of the washer could cause the cycles to be messed up as water may be in the washer when it's not supposed to be, and that confuses the control.
    Genius:
  • 1,122 Answers
If the sink and washer drain are tied together which i don't think it is,if washer drian was cloogged it would overflow behind the washer,most of the time if a washer will not spin or drain it's the door swich gone out-mike
Ok I have a Frigidaire combo FEX831fs1. It won't drain. I replaced the pump and the belt. still wont drain. In the drain cycle it makes no noise at all. Spins, fills, agitates, just wont drain.
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Apr 11, 2017 | Frigidaire Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Water discharges out of the machine into the kitchen sink,when draining water from the sink its very slow to drain (maybe blocked waste pipe?) but now i realize the water is rising up to base of the drum...
Sorry to read about your problem, I hope this helps you out.
you have 2 different issues. Blocked waste pipe and a defective water fill switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Washing Machines
Miele novitronic w830. Drain wont work. I've cleaned the outlet of dirt and the wheel inside the outlet is spinning freely. Reggadles, red light comes up.
Have you tried checking the drain spigot under the sink where the waste hose connects as it can be blocked at this end?
Try draining the unit into a bucket instead of the sink this will eliminate the washing machine as being the problem if it works ok.
is the drain pump actually turning? select drain or drain spin and have the fluff filter (outlet) removed so you can see if it is turning. if it isn't turning there maybe a broken wire to the drain pump causing it not to turn or the drain pump is jammed with something although you mentioned you could spin it freely.
hope this helps
Jun 01, 2010 | Miele Novotronic Premier 500 Front Load...
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
My GE washer will not run a full cycle. It fills up non stop, while at the same time its draining. It was running the cycle and would get stuck on the rinse/spin cycle. But now the knob doesn't even move...
One very slim chance is that the waste water hose does not have an air break in it
The pipe is supposed to be placed into a drain which allows a flow of air to the pipe out of which the water is being pumped
If there is not an air break then the mchine can set up a syphon action which will not allow the unit to fill to the right levels
Quick check is to dump the oulet hose into a sink and run the machine , be sure to secure the pipe in case it slips out and also that the sink can empty fast enough for the water being pumped into it by the washer .
If you are saying that the machine wont stop filling try turning the water off at the fawcet
Jul 05, 2009 | GE Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
My font load washer wont fast spin or drain
gimme those older models anytime. their having a lot of trouboe with this front loaders
Jan 07, 2009 | GE WSXH208A Front Load Washer
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Indesit W 123 Front Load Washer Logo
302 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
