Question about JVC AV-48WP30 48" Rear Projection Television
Sony kp-53s15 convergence
The electrical power was lost, and when the power is restored the convergence isn't adjusting as it should help!
  • Eric09 May 08, 2009
    I have the same problem. Had a power surge and the convergence especially on the top left and lower right corners are way of.
    President:
  • 3,130 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point, is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Posted on Jul 05, 2009
  • 25 Answers
IF THE RED OR BLUE ARE ALL OVER THE PLACE ,IT MIGHT HAVE BEEN A SURGE ,MAY NEED TO CHANGE OUT THE CONVERGENT CHIP .HOPEFULLY ITS EASIER TO GET TO THEN A TOSHIBA! $10 PART X40 IN LABOR.
Posted on Feb 06, 2009
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
Sony kp-46v15 convergence problem dont know were to start on adjusting main convergence board in front were do i start there is 15 or so red green blue ajustments for horizontal and the same for vertical...
Do not mess with those, they don't just go out. they are also for skew linearity, heighth, width for vertical and horizontal adjustments. If your convergence went out need to find convergence circuit and look on the plugs for your vcc voltages going to the convergence circuit. If missing, trace back to power supply and look for an open low value resistor.
Apr 20, 2011 | Sony KP-46V35 TV
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
TV will not come on
i have a sony rear projection TV, model number kp43t70 screen went black and there was still volume but no pic so I turned it off and now won't turn back on
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony tv
if you go into the convergence mode in the customer menu does the red convergence adjust? if it does not you have a bad convergence Ic--set uses two of them, have both replaced and set adjusted and you will be back in business---if this is helpful give me a vote; if you need more direct help-----------: etower.766@netzero.net
Aug 11, 2009 | Sony KP-43HT20 43" Rear Projection...
CONVERGENCE IC ADJUSTMENT
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Oct 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Blue convergeance
Can you use a meter and solder? If you I can help you fix it. If not you will need to call a repairman. let me know what you would like to do!
Tim Nolan
Sep 13, 2008 | Sony KP-53S65 53" Rear Projection...
Loss of electricity due to the ice storm...
if it worked before and not after i would claim it, also sometimes if you complain to the electric company they will foot the bill on there insurance. power surge can cause all sorts of problems . just my 2 cents.
now this set is also know to have bad convergance ic
check this site out for repairing it.
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
By manual convergence, if you mean electrostatic convergence, then I'm not sure this is included in the service manual. However, if you join the http://groups.yahoo.com/sonyhdtv/ group, there is a file download called ws500tweaks.doc that documents this (with the usual caveats, like don't get yourself killed, when in doubt hire a pro, etc).
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Convergence problem
Sounds like bad solder connections on the convergence circuit board. Better get it looked at before the damage becomes permanent.
Jan 28, 2007 | Sony KP-EF41 41" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
247 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
