Question about LG CU515 Cellular Phone
Connect LG CU515 to Motorola H500 Bluetooth
Haven't been able to get devices connected and I can't find the CU515 manual. Following the Motorola H500 manual doesn't work.
    Problem Solver:
  • 5 Answers
Here is the manual for the lg CU515: http://www.wireless.att.com/support_static_files/manuals/LG_CU515.pdf
however, you should just be able to go to the bluetooth menu, select "search new device" (looking for "Motorola H500"), then press "add" - the passcode should be "0000" (without the quotes)
Posted on Feb 07, 2009
Please help
Go to the Motorola web site and find the user manual for the H500. The instructions are there. The passcode is probably 0000.
Go to the LG manual for Bluetooth to find out how to get the phone to search for the new device when adding a device. The steps are probably something like this:
1. Turn on the earpiece and the phone.
2. In the phone menu, go to Setup or Options, then Bluetooth, then Add Device.
3. Choose Search for a Device
4. The phone will find your earpiece, so select it
5. The phone will ask for the passcode, so enter it (again, probably 0000 but check the H500 manual)
6. Wait several seconds for them to synch.
7. You are ready to go
Sep 01, 2009 | Motorola Mobility H500 Headset
Motorola bluetooth headsat h385 for phone lg(kp170)
Click on the link below to open the user manual, and follow instruction on PDF document:
BEFORE YOU BEGIN CHARGE START BLUETOOTH FEATURE
Mar 02, 2009 | Motorola Mobility Universal Bluetooth...
Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
Feb 28, 2009 | Motorola Mobility H500 Wireless Headset
Need passkey number to connect bluetooth to blackberry
Usually they're 0000. You may have to hold down the answer button as you turn it on, or hold it down for 10 seconds to put the device into pairing mode. Check the manufacturer's manual for more specifics.
Dec 15, 2008 | Motorola Mobility H500 Headset
New phone can not find bluetooth H500
Power off the H500. Hold down the power/activity/main large button (have no idea what Moto really calls this) for 6 to 8 secs. The LED ring should stay lit solid at this point and is in discovery mode. Now have your phone search for the headset. Default password on the device is 0000.
Aug 05, 2008 | Motorola Mobility H500 Wireless Headset
How do i connect H500 to my phone
Hey guys. found it. Go to
www.simoncells.com
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Ed
Feb 18, 2008 | Motorola Mobility H500 Wireless Headset
Bluetooth
What are you trying to send? Picture, video, ringtone, app?
For a ringtone, go to the Media Finder, select ringtones, then "All Ringtones" and scroll to the one you want to send. Hit "options" and scroll to the option "Send"
Select "Send" and one option should be "send Via Bluetooth"
The process should be similar for other sendable items.
Feb 02, 2008 | Motorola Mobility RAZR V3x Cellular Phone
H500 bluetooth
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
Dec 31, 2007 | Motorola Mobility H500 Headset
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
LG CU515 Cellular Phone Logo
1,273 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
