Question about Hotpoint 3.5 cu. ft. / 99 liter Upright Freezer RZA30
Hotpoint Freezer I have a Hotpoint Fridge Freezer Model FFA60 - the middle basket of the freezer has broken - where can I get another one
    Problem Solver:
  • 19 Answers
Get a hold of CAMCO, they are the authorized parts/repair depot for Hotpoint
Posted on Feb 07, 2009
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
Feb 09, 2018 | Hotpoint Freezers
Kenmore fridge over pullout freezer. Freezer has snow. Model 59673502201 . Fridge runs, and shuts off apparently normally. Freezer is cold, air blowing (fan?) from behind freezer temp control. Thought...
Please : - Clean up your freezer - set the thermostat to middle - check the fan for malfunction
There are many things that cause your freezer work abnormally.
Nov 07, 2010 | Kenmore Freezers
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Smell from fridge freezer even after thorough cleaning and disinfecting and defrosting Model Hotpoint RFA52. Temperature control OK
Put Charcole brickets in the refrigerator. Charcole works better than baking soda and usually take care of the smell.
Feb 20, 2009 | Hotpoint Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Hotpoint 3.5 cu. ft. / 99 liter Upright Freezer RZA30 Logo
348 people viewed this question
Top Hotpoint Freezers Experts
Justin Duby
Justin Duby
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
