Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Panafax UF 895 problem with ADF. I can load paper successfully in the tray(machine recognizes loading of paper) but rollers never move. Display reads, Misfeed/ Code 030. I don't have a manual but I am a tech. Thanks
  • 55 Answers
your code 030 is a misfeed, here is a link for the manual
http://www.businessneedz.com/Manuals/Panasonic-Panafax-UF-890-Owners-Manual.pdf
Good Luck
Posted on Feb 03, 2009
What to do about the ADF pulling too many sheets through?
Make sure the pick up roller is free of paper dust. You can get cleaner paper at an office supply store. It is sticky on both sides and will remove paper dust from the surface of the pick up roller.
Aug 21, 2014 | Panasonic Panafax Uf-8000 uf8000
Paper found jamed again & again from main tray only
You have to remove paper tray & back cover and clean every rubber parts and rollers carefully.problem occurs again change worn rubber parts.
May 15, 2014 | Panasonic Panafax UF-4500 Fax/Copier...
ADF won't pickup paper off Panafax UF790
Open the ADF door and clean rollers and ADF pad with windex sprayed onto a paper towel , if problem remains call service tech to replace parts required.
Sep 29, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Regarding my Panafax UF-8000: Why does evrey page misfeed? I started with 24lb white paper and switched to 20lb, but still it is misfeeding.
clean the rubber feed roller/rollers that actually feed the paper from the paper tray.. clean soft lint free cloth dampened with water
Mar 31, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Message that says "recorded paper is not loaded properly"
Could be 2 things.
Take the cover off of the paper tray and reinsert the tray
The tab on the left side front of the paper tray could be broken off.
Respond and I will tell you how to fix it.
Dec 03, 2009 | Panasonic PANAFAX UF-6000 Fax
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
ERROR CODES 016 AND 010
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
Paper Jams
Try changing out the toner cartridge if cleaning rollers didn't work.
Jan 07, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
424 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
