Question about Google Talk
I am receiving this message on Google Talk- Connecting to Google Talk network has failed due to an expired authentication certificate. The common cause of this expired certificate is due to time differences between your computer and the Google Talk network. Please verify your computer's clock settings are correct and then press Retry. I've checked the settings and everything is fine. When I try to go to gmail or my blog, I get this notice on both IE & Firefox- Secure Connection Failed www.google.com uses an invalid security certificate. The certificate expired on 5/2/2009 12:02 PM. (Error code: sec_error_expired_certificate) * This could be a problem with the server's configuration, or it could be someone trying to impersonate the server. * If you have connected to this server successfully in the past, the error may be temporary, and you can try again later. Server down? Everyone having this problem?
  • 25 Answers
you can view this link, to get a better solution:
http://www.google.com/support/talkgadget/bin/topic.py?topic=15386
thank you,
Posted on Feb 11, 2009
Google talk sign in not open cnnection error
"This error most commonly appears when you have no connection to the internet.
If your internet connection is working, you may have an issue with your firewall or proxy server. First, make sure that your firewall is configured to Allow Google Talk; we've provided instructions for some of the more popular firewall applications below:
A proxy server requiring a proxy username and password could also cause this problem. To configure your proxy:
  1. Open Google Talk.
  2. Click Settings .
  3. Highlight Connection along the left side of the dialogue box.
  4. Select Use the following proxy .
  5. Check the box next to Proxy requires Authentication .
  6. Enter the proxy username and password.
  7. Click OK .
Finally, your network administrator may have disabled Google Talk on your network. If you continue to see this error, please contact your network administrator."
Google Support
Aug 06, 2011 | Google Talk
Connecting to Google Talk network has failed due to an expired authentication certificate. The common cause of this expired certificate is due to time differences between your computer and the Google...
Right click on the time on your task bar thats at the bottom right of your screen. Check to see if your time and time zone are correct if they are go to www.gmail.com and log in then go to settings and make sure that the time zone is the set right there. One of them will be not set right. Once that is corrected you google talk will work.
Nov 26, 2010 | Google Talk
When I try to sign in google talk I get a message "could not authenticate to server". How to solve it?
If you can't sign in to Google Talk, or you're receiving an error that says, Could not authenticate to server, check if your computer is behind a proxy server that requires a username and password. if you have personal firewall software installed,
Thanks
Dec 24, 2009 | Google Talk
Sync b/w google talk servers and my comp clock???
Verify the date and time are correct on your system.
This seems to be the number 1 cause for this.
Oct 02, 2009 | Google Talk
Problem in signing in G talk
Please check the date(time) settings on your computer. Click on the lower right corner to do this. It should solve the problem.
Please rate if the problem is solved.
Apr 04, 2009 | Google Talk
Gmail, Blogspot & Googletalk
hello, this is the problem with the SSL security certificate.. to solve this problem in firefox ... first when this error is displayed there wil be a link that says " add this certificate " , click that link and add the certificate to ur browser.. the problem will be solved ... or else go to internet options in ur browser and check for certificate settings .then download the certificate from google with the option given there....
Feb 03, 2009 | Google Talk
Google Talk problem
To resolve this problem adjust the Date and Time Properties of your computer.
Sep 15, 2008 | Google Talk
Connecting to network
[QUOTE]The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
Google shows 37 hits with this exact phrase.
This is caused by setting the encryption to WPA-RADIUS instead of
WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it
will work.[/quote]
Jan 16, 2008 | Linksys Wireless-G WRT54G Router
Google Talk Logo
447 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
