Question about Sweet Beginnings Cabana Stripes Crib
Riso tr1510 he two large wheels pull the paper into the machine. Once the paper is halfway in it stops and the jam light comes on. It seems like a timing issue. The paper buckles a bit when entering the feed rollers. Dan
  • 22 Answers
Take one of those flat plastic rulers and push it through all over.. so that any forein ripped paper whatever, clears the way.. The paper is supposed to buckle on entry.. That's how it's designed. It could be a timing issue.. when the paper is fed in it buckles against the timing roller.. the roller turns only when its supposed to. Each sheet stays buckled against the timing roller until it turns, that's how the machine draws only one piece at a time. It's could be the feed clutch.. There's a little magnetic clutch that actuates the feed roller to pull the paper in. when this feed clutch gets weak it barely works or it slips and doesn't pull the paper in at the right time. I've replaced these often on my equipment.. but I've also found that static electricity plays a big role. If your area is too dry, the paper sticks together increasing the resistance, pulling either multiple pages or just too much resistance for the feed rollers.. screwing up the time.. Make all adjustments to the feed rollers first to ensure it's not a huge problem before you start looking for a clutch. Essentially if the paper doesnt make it into the feed roller on time it is a timing issue.. but it's starting from the feed rollers.
Posted on Aug 11, 2009
    New Friend:
  • 17 Answers
Probably a bad timing or guide roller. Sounds like 1st paper feed works, but if it does nothing after the buckle, then 2nd paper feed isn't working properly. Check in back to make sure all springs and present and hooked on, and that the gears are working properly.
Posted on Mar 30, 2010
Canon k420 copier
In some cases, not all; the paper feed rollers get dry and slick. If so they tend to feed at times and sometimes stop halfway at times. Look at your rollers.
Jan 17, 2014 | Computers & Internet
Error Code P-04-513
P04-513 is an ink overflow error.
the easiest way to fix it is to run the drum dry.
here is how:
1. turn the machine off by the power swith.
2. hold the left and right print position buttons and turn on the machine.
3. when the machine starts it will show you some numbers.. perss either the clear or yellow reset button to show 0000
4. now enter 81 and press start and the machine will make a master.
5. once the machine is done press the clear or yellow clear button to return to 0000
6. next make suer you have plenty of paper and enter 888 and press start.. the machine will start making copies of the test pattern. (if it jams a lot you may want to use speed 1 or go to step 4 and use code 80 instead)
once the copies start coming out light you can press the stop button and when the machine stops turn it off and back on normally.
Dec 19, 2012 | Riso RZ390 Duplicator
Where can i download free service manual for RISO TR1510?
I found one here.
Mar 10, 2010 | Riso Office Equipment & Supplies
Need manual for riso tr1510
I doubt these exist in an electronic form. Best bet is to contact RISO directly at 800.942.RISO for assistance.
Jul 17, 2009 | Sweet Beginnings Cabana Stripes Crib
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Paper feeding problems Riso TR1510
refix your ink cartrdige also check there is not any paepr jam issue.
also some times printer neeed servicing creates this type of issue.
Mar 28, 2009 | Riso Office Equipment & Supplies
first try paper feed clutch.. make sure nothing is blocking paper path...
Feb 03, 2009 | Riso RZ220 Duplicator
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Riso GR3770 Paper Jam, Check paper feed
Sounds like you forgot to plug the High voltage transformer or a sensor back
Dec 11, 2007 | Office Equipment & Supplies
Sweet Beginnings Cabana Stripes Crib Logo
297 people viewed this question
Top Sweet Beginnings Baby Gear Experts
Dorel UK
Dorel UK
Are you a Sweet Beginnings Baby Gear Expert? Answer questions, earn points and help others
