Question about eMachines T6534 PC Desktop
THE SCREEN SMEARS NAD SHUTS DOWN
WHEN I WAS ON THE COMPUTER OR INTERNET THE SCREEN WOULD SMEAR OR HAVE ZZ LINES. THEN IT WOULD SHUT DOWN.I THOUGHT IT WAS THE VIDEO CARD ON THE MOTHER BOARD.( EMACHINES T6534) SO BY THE TIME I WAS WAITING FOR THE CARD IN THE MAIL. I WAS HAVING PROBLEMS BOOTING MY SYSTEM.I PUT THE CARD IN AND WAS DISABLEING THE OLD ONE IT SMEARED AGAIN AND SHUT DOWN NOW I CANT GET IT TO BOOT. I PUT IN THE RECOVERY DISK IN,NOTHING.HOW CAN I GET IT TO BOOT TO FINISH. IS IT MORE THAN THE VIDEO CARD? EVERYTHING POWERS UP.I HEAR THE HARD DRIVE TRY TO START, KINDA A TICK TICK NOISE AND THEN NOTHING.I HERE THAT FROM DAY ONE AND IT USELY KICKS IN GEAR.
  • eakesj Feb 03, 2009
    thanks for fast response. can i unplug the hard drive to see if it will reboot?i have a old windows 2000 hard drive can i test with that? and why would the computer boot at times then sometimes it would take for ever to boot. and does the video card have anuthing to do with whats going on?
  • 797 Answers
Hi eakesj:
A number of things here should be checked.
First shut down and remove all cards, and power connections to all the drives such as cdroms, hard drives.
The power supply should also be looked at and tested for correct voltages on each wire. This can be done with a voltage meter.
Turn on the power and see if you can get the machine to start to the bios screen. (this will work if you have a video processor on board, if you have a video card, you will need it to use the monitor).
If that will not work, then you have more problems than you thought at the beginning.
If the mother board will not work at this point, then you have problems with either the mother board or the cpu processor. There is a possibility that there are problems with the memory modules.
So, if you have only one memory module, then I would remove the memory, carefully clean the contacts, (a clean pencil eraser can work, if you are careful, and do not press very hard) and then plug the memory back in and try again. Also if you have extra modules of the same type, try one for testing.
If you are still having the same problems, then the mother board or the cpu is the problem. At this point you should consider if you want to continue and repair or buy another mother board of the same size. If you buy another kind of mother board, remember you will have to re-install your operating system over the original one to get the complete setup and the bios to work correctly with it. Many times this can be done, but you risk losing data (you will lose all data in MY DOCUMENTS), and may have to completely re-install the OS. You may want to install the drive in another computer as a slave and back up any data you want to save before you proceed.
If you decide to continue with your original mother board, and still have problems, then the cpu or the mother board is suspect. To test the cpu, either test your board with another cpu which is compatible, or check the mother board with another mother board of the same exact model.
Hope you find the problem.
Posted on Feb 03, 2009
New 60" lg TV has a crisp white smear with pinstriped lines
Bring it back. You have done nothing wrong and the dealer may have a Bad Batch of units.
Mar 22, 2014 | Computers & Internet
Whistle in computer
Bogus unit - return it for another.
Aug 21, 2017 | E-Machines eMachines Desktop PC
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
Accidentally pressed FnF1 when i wanted to enter BIOS.Laptop has Linux and I didn't get to place the boot CD in yet.When I press Power,zz turns on and remains,and I have a black screen.Won't come out of...
Press the ON/OFF button, and hold it down until the computer shuts itself off.
Release the button.
Press the button, to restart the computer -- it should restart "normally".
Apr 20, 2011 | Computers & Internet
I have a 3 year old Nad C315BEE which shuts down after around 20 minutes play, after it cools down and resets it`s fine, looks like a thermal cut out problem. Any ideas as to the cause. It`s not enclosed...
Does it actually FEEL hot when it shuts down? Ther could be dust bunnies inside it.
http://www.retrevo.com/support/NAD-C315BEE-Amps-manual/id/8043dj584/t/2/
These things only have so many protection cycles in their lives. If you can't find a cause for the thermal shut-down and resolve it you should take it to a tech for a check-up.
Jan 16, 2011 | NAD C315BEE 2Channel Amplifier
Phone lines shuts down
Sounds like you need a service tech to check your connection out there. VOIP hates latency and if it detects it, it will shut down.
You can go to PingPlotter.com and they will show you have to check if you have a good internet connection.
Aug 21, 2017 | Linksys SPA-2102 NA Analog VoIP Adapter...
Frozon screen
Always use CRTL/ALT/DELETE to shut it down when something like that happens.
It damages the HDD if you do not shut it down correctly.
Unplug the power cable from the computer and let it sit over night. Plug it back in.
is your computer XP or Vista?
please let me know.
Thanks!
Jan 27, 2009 | Sony VAIO PCV-RZ221 PC Desktop
Kp-57ws500
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
May 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Computer shuts down when VCR is set to
the first things i would try is updating your video card drivers and install the latest version of directx
Mar 24, 2008 | Computers & Internet
eMachines T6534 PC Desktop Logo
205 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
