Icute matx cube wiring
I lost wiring instructions for this case and am needing to know how to wire the lcd front panel. please help thanks Luke
  • Peter Steiert
    Peter Steiert May 11, 2010
    Do you mean the wiring for the LEDs?
  • 21 Answers
There should be some spare tiny wires available and these should be colour cordinated in some cases
Posted on Feb 28, 2009
Need a schematic to wire front panel on n1996 ms 7061 motherboard.
1) http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07557&lc=en
2) http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the photo, and pinout, of a 9-pin HP Front Panel header
(No.9 pin. Reserved. It is/was, reserved for the factory.
5 Volt DC test point. It is N/C. Not Connected)
Nov 26, 2012 | MSI : MS-7061-020...
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I don't know how to open the case? It has a side panel clear blue led lights
you will need a rubber replacement for your R1 button, if you or a friend have a defective joystick consider that a replacement. if you can't find a defective joystick you can buy a ps2 rubber kit online. below are reference pics.
1. Remove 5 screws with a philip screw at the back of the joystick.
2. Split the two covers with caution.
3. Carefully remove the rubber beneath the R1 button and replace it with a new one.
4. Put together the front and back part of the joystick.
5. Test the replaced part and screw if you're satisfied.
Hopefully this information helps.
thank you for using Fixya..
Jul 26, 2011 | iCute 408Black w/Side Window LED 400W Case...
Have no manual for icute A78BN ATX case, how to connect the right cables to the ECS motherboard.
just plug the 20 or 24 pin from the PSU to the motherboard. it's the only one, you'll never missed it
Mar 02, 2010 | Computers & Internet
How do I open my iCute 314 ATX case?
Hello!
The iCute 314 is a very easy case to open.
First, I assume that you are trying to get into the side panel of the case.  Lay down some protective paper or bubblewrap (so you don't mess up such a nice case!).
Then lay the case over on its side, with the clear side facing up. On the underside, you will see 4 chromed thumbscrews.  Unscrew these, making sure not to lose them. Taking the side cover off is somewhat different from a lot of cases in that you slide it towards the *FRONT* of the case instead of backwards.
Closing up the case is just as simple as reversing the above steps. IMPORTANT NOTE:  For all repairs/mods, you should have the power disconnected before messing around with anything inside the case.
Note 2:  If you don't know what you are doing, don't mess around inside the case!  I have had more repairs not from computer part failure, but from people messing around inside the 'puter without knowing what they were doing.
I hope all of this helps.  You do have a nice case for your system!
Ken
Jan 05, 2009 | iCute 314 ATX Case
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
Icute to motherboard wiring
Hi, on the edge of your mother board closest to the front of the computer, you will find a double row of pins. Use a torch and if needed a magnifying glass and study these, you will find they are labeled the same as your cables from the case.
In some cases the plugs are set as a 3 space plug, if you find one of these that wont fit. just split it. If you plug the LED wire back to front, don't panic it won't hurt they just wont work. The power and reset are not pole sensetive.
Goodluck mistyman
Dec 23, 2007 | Computers & Internet
Computers & Internet Logo
388 people viewed this question
David Payne
David Payne
