Question about Toshiba Estudio 200L Copier
E-studio copier won't multi feed, it jams
My top feeder jams from the 1st sheet. Upon opening the upper cover, I notice the gear takes a lot of effort to turn. What can be done so I can stop making copies page at a time.
  • mbeekmans Feb 03, 2009
    I just did that thanks, but it seems to be the "gear" that is not even moving but does try. The mechanism seems bound up or something. My maintainance co closed, so I found Toshiba soluttions in King of Prussia, Pa. Anyone know if they are legit and good?
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; Open the feeder cover clean all the rollers by rubbing alcohol or rubber rejuvenator( recomend) it should take care the problem.
Posted on Feb 03, 2009
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
    this is not a thought I am 100% sure and give you the correct solution:
    problem with the paper feeding section is dusty or due to developer drooping
    1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
    and drop the developer.
    2. remove all paper trays with remove the four each screws
    3. Remove the toner collection bottle
    4. Remove the right side cover.
    5. Remove paper left roller plate.(show in the picture)
    6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
    7. Clean the drooped developer from all gears and roller and motor section
    8. remove the second and third tray paper feeding section and doing the same.
    9. now fix it all
    10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
    Jan 27, 2011 | Ricoh Aficio 450 Copier
    No matter what i do the paper keeps getting jammed before it comes out... It looks like it's getting hang up on something by the front rollers... This is really making me very mad this morning....
    I understand your frustration. Try this solution.
    * Push down the purple paper lever located on the right side of the multi-purpose sheet feeder and pull the jammed paper upward and out of the feeder.
    * Open the scanner cover by pulling the lever located below the control panel, toward you and lifting the cover. Make sure the cover is completely open. Check to see if any paper is left in the paper path.
    Close the scanner cover.
    Remove the paper in the multi-purpose sheet feeder. Adjust the guides in the sheet feeder to the position for the paper size you are using. Fan the paper well, push down the paper lever. Load the paper with the lever down. Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper (20lb paper) or up to 10 envelopes.
    * Turn the power back on.
    I hope this helps you.
    Aug 03, 2010 | Brother DCP 1000 All-In-One Laser Printer
    My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
    Hello.
    You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
    Sheet Feeder or Manual Feed Slot: Press the
    paper button to eject any jammed sheets, then open
    the printer cover and remove any paper jammed inside.
    Press the paper button again to clear the error.
    Hope this helps.
    May 31, 2010 | Office Equipment & Supplies
    SCX 4521F multi/f keeps reporting "Document Jam"
    Hello there,
    If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for Laser printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    do not forget to rate this solution....good luck
    thanks for using FixYa
    Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
    Paper jam
    Turn the printer off and open the access cover.
    Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
    Watch the paper as it feeds through and try to determine where the jam is occurring.
    Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    Turn the printer off.
    Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    Ensure that:
    The paper is a recommended paper for inkjet printers.
    Mar 24, 2008 | Office Equipment & Supplies
    Paper jam error message
    I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
    The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
    Dec 28, 2007 | Canon PIXMA iP1600 Printer
    Dell 1600n Will only print with sheet feeder open
    Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
    Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
    Cannon pixma 1600
    I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
    The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it), and then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
    Nov 25, 2007 | Canon PIXMA iP1600 Printer
    106 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
