Question about Nokia 7373 Cellular Phone
Phone wont stay on for longer than five minutes
Screen keeps going white and then switches itself off
  • hollyberry2 Feb 05, 2009
    every time i turn my phone on a little G in a
    circle comes up on my screen and then a message envelope spinning
    around and then the screen goes white and my mobile switches off, iv
    tried restoring the factory setting but it asks for a security code
    which i dont have. at the moment i cant keep my phone on for longer
    than 5 minutes. iv tried deleting everything but everytime this little g comes up on the screen followed by the message envelope it just goes white and then switches off
    Problem Solver:
  • 9 Answers
According to me your phone requires to download the new software's in it (it is also called as flashing).
or please contact your nearest service centre...........
Posted on Feb 03, 2009
    Scholar:
  • 61 Answers
There are a few steps you can take to have this resolved. It could be a memory issue, battery issue, software issue, or a hardware issue. Start with getting rid of any un-needed sms/mms mssages. Clear call log. Any data dowloaded you don't need.
Now, do a powercycle, turning the phone off for 10 to 15 seconds. Power back on. Does it stay on longer? How strong is the battery? Did you fully charge the battery? Do you let the battery deplete completely before putting the nokia back on the charger. This is important for battery memory and life.
If this is not the answer. Do a master reset....Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#
You'll wanna back up contacts using Nokia PC Suite, a free download from www.nokia.com/pcsuite for computers with Windows 2002 or higher.
We just looked at the memory and software, if this still doesn't resolve the issue. Do a battery test! Try a new batttery or your battery in another like Nokia. See where the problem follows. If the problem follows the phone, check the warranty with your carrier or with Nokia.
  • Krissy-Lee Dooly Feb 05, 2009
    The default code for your Nokia when doing a master reset is 1235. IF that doesn't do it, then contact NOKIA to get your phone flashed. It'll completely wipe everything out.
    If you need further assistance, please Call the Nokia Care Contact Center:
    Telephone: 1-888-NOKIA-2U (1-888-665-4228)
    TTY/TDD: 1-800-24-NOKIA (1-800-246-6542)
Bryant 345mav furnace shuts down early after one minute
Try to jump pressure switch as soon as the inducer come on and see if it stay longer. if it does you might have problem with draft or pressure switch itself defected.
Nov 28, 2013 | Heating & Cooling
My samsung rant keeps turning itself on and off
Have you taken the battery out for more than one minute? has the phone gotten wet?
Apr 04, 2010 | Samsung Rant Cell Phone
My ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Screen got blank
switch off the phone just five minutes
Aug 16, 2009 | Nokia 7210
The washing cycle takes much longer than the time listed on the panel.
Sounds like the pump may be clogged. If it doesn't get rid of all the water, it wont' spin. Remove bottom panel. Locate what looks like a big white screw. Remove counterclockwise. (It's tight). Have a bucket ready under neath, or a shop vac. Remove slowly to catch water as it comes out. When you pull the white part of the pump all the way out, there's probably things clogging the holes.
Apr 25, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Message problem
That sign is GPRS go to network seting and stop GPRS
Feb 05, 2009 | Nokia 7373 Cellular Phone
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Power on/off problem
If possible go for a repeareing.
Feb 18, 2008 | Computers & Internet
Nokia 7373 Cellular Phone Logo
104 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
