Question about HP Compaq nc6320 Notebook
HP NC6320 - drive not detected or found during OS install
I formatted the drive that came with the system (seagate) attempting to install a fresh XP Pro OS. When I got to the install windows selection on the boot disk it said the HD couldn't be found. I did see on HP's site where they had firmware for the HD to solve this issue but now that the HD's been formatted that firmware can't be installed. (it was an exe to be run with the OS installed. I also tried another disk, different make but same result. two questions: way to update firmware on drive (sub maybe) ? two: could this be a bios setting to protect data? I don't see anything in there but the HD cover says it has an HP Mobile Data protection System"
  • dclemmons Feb 03, 2009
    That's a good solution for erasing the current HD but I'm seeing the same issue with a brand new drive I used. That one didn't have any data protection installed and the laptop didn't detect that one either.  What about the laptop itself having the protection, Possible?
  • 20 Answers
That is a possibility that it has a data protection. Try this download the super FDisk and burn the ISO to a DVD. then boot off of it and delete all partitons on your HDD that way it will be erased so you can start over new. You might be able to do this on HPs boot disk too. Unfortunately you cannot update the HDD firmware after the drive has no OS on it. In this case you need an outside tool to totally erase the HDD so the install can see it again.
Posted on Feb 03, 2009
  • Aaron Andino Feb 03, 2009
    Have you formatted the HDD with the built in software for windows install or used a separate program? Is the HDD seen in the BIOS menu as a boot device? You may need to make a change there.
Unable to format Seagate ST9500423AS
Have you tried reformatting your hard disk? this happened to me when i tried to us PartionMagic tool. my hard disk stopped working tho' it's still showing up when i plug it in another PC. this is how i get it working again:
i plugged my hard drive to another PC and i used DiskPart to clean it and i formatted it in Windows Disk Management.
it worked for me and i doubt, there was an error partitioning my hard disk so i needed to make it fresh again.
Apr 18, 2013 | Seagate 500GB ST9500423AS 7200rpm SATA2...
Im trying to put a new seagate 40gb sata hdrive into my hp nc6320,when i try to load xp to install it tells me there is no hard drive in the computer
New Hard drives do not come with an operating system on them. It's basically a blank disc. You would need to have an XP operating installation disc or the original system restore discs that came with your computer in order to load the XP operating system. If you do not have either of these discs, you will need to purchase an operating system and install it so that you have something on the hard drive to run.
Mar 01, 2011 | Computers & Internet
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Operating system not found
You can't insert a Hard drive from another PC because when it was installed on the old PC it was setup to work with the hardware for that particular computer.
You will need to reinstall a fresh copy of windows on it to make it work with the new PC it's in.Boot from CD run windows setup, format the drive then do a fresh install.
This should fix the problem, if you have any new info or need further help with any of that post back. Thank you for choosing Fixya!
May 27, 2009 | Microsoft Windows XP Professional
How do i format the seagate 5400 160 gig hard drive?
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
There ya go ya tubby *****.Give me a shout this weekend, Mike
Mar 29, 2009 | Seagate Momentus 5400.3 Hard Drive
How to install xp on vista compatable laptop
you might try formating the hard drive first then installing xp. or you could fix it to where it boots directly from the cd
Sep 24, 2008 | HP Pavilion dv6000z Notebook
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Compaq restore cd
Hi mithz.
I'm not you people.
(Please keep track of the user who you ask a question too).
When you installed windows 2000, (If you formatted the entire drive during install), you might have taken out the small partition that holds data for a system restore. No version of windows likes
you going backwards. In order for you're system restore CD's to work you'll need to format the hard disk drive. Windows will not install if Windows 2000 is found on the drive. The fastest way to get Windows 2000 off the drive without deleting any other partitions Compaq installed would be to go to the hard disk drives manufacture's site & download their setup tools/utilities. You'll be able to creat a bootable floppy disk that will function in a dos-like mode out side of windows. You'll be able to format the Windows 2000 partition. Once that is done you will be able to incert the restore CD (s) & install Compaqs windows XP.
You may need to pull the drive in order to see who made the drive. EX; Seagate, Smsung, Maxtor ect. Here is the link for Seagate.
Every manufacture has similar bootable floppy software.
Read the instruction provided by the manufacture on how to create the floppy disk & how to run it.
Good Luck!
Jul 15, 2008 | Compaq Presario 5000 PC Desktop
I'm new to building pcs and this is my first build. I have two Seagate Barracuda 7200.10 ST3250310AS 250G hdd's installed in my newly built pc. I have yet to detect a driver when trying to install ...
There are many ways to format your hard drive but i will tell the two ways.
  1. while you installing the os like windows xp,2000 it ask you to format the hard disk to install the windows operating system. It comes before the copying the files into the hard disk while you install the windows.
  2. Another way is formatting the harddisk is by seagate software like DM (Disk Manger) is comes with the harddrive or you can download the software from the seagate website for free. DM is the software for formatting . so you can format your harddrive by these software.
May 03, 2008 | Computers & Internet
Can't reinstall xp pro on my hp compaq nc6320
Stephane, I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this: Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not. Best of luck! Bryan P.S. If you want to enable SATA native mode after you have installed XP Pro check out this link:
Oct 04, 2006 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
390 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
