Question about Baxter OV300E Stainless Steel Electric Oven
I have a baxter mini rack electric oven and water started leaking out of the right side of the oven while cooking bagels. any ideas on what is causing this
  • 43 Answers
Sounds like you have a water leak! The right side panel needs to come off. Here you will see your copper water lines. Try steaming while watching to see where the water is coming from, most likely its coming from the two spray nozzles that enter the oven near the top in the front and rear. If the leak isn't obvious have an authorized technician service the oven. A leak in this part of the oven left unattended could cause more damage and potentially a fire.
Posted on Jan 13, 2012
3 Suggested Answers
SOURCE: 1985 Baxter 30 tray- Oven is set at 496F, oven
Replace high limit, check if the vents are dirty (bottom right and left circlular holes covered in "chicken wire" they could clogged , they are the air intake for the burner , also clean back of the green mixing valves
Posted on Nov 24, 2010
  • 910 Answers
SOURCE: Hi! I have a baxter OV300 1999- The rack stops
I suspect the drive bel tis worn and slipping.
Please refer to Page 28 of the manual at the link below to inspect the belt.
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/F36704.pdf
If this is OK and/or you need any further assistance then please just ask.
Posted on Jul 21, 2011
I have a Baxter ov310e oven a customer asked me to check on. Of course while there had no issues at all. She said when they were using it earlier in the day the temp diplay started flashing. It was near...
SAFETY ALARM (STANDARD FEATURE, NO PARAMETER SETUP REQUIRED)If the temperature at the probe is in range of 570 to 600°F for 10 seconds, the unit will do the following:1. Shut off all features.2. Sound an alarm.3. Flash the OVEN TEMP display (actual temperature is displayed).4. Display the letters 'SHdn' in the BAKE TIMER display.Disconnect the electrical power to the oven and follow lockout / tagout procedures.There may be multiple circuits. Be sure all circuits are disconnected.
Troubleshooting - Baxter OV310E Operation Manual [Page 29] https://www.manualslib.com/manual/1248539/Baxter-Ov310e.html?_e_pi_=7%2CPAGE_ID10%2C4341941345 -- shared by UC Mini
Jan 19, 2018 | Baxter Ovens
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
Where is the reset button
All the breakers on an electric OV300 would be accessible from the small access panel on the front lower right side of the oven, there should be a sticker on the door that says something along the lines of "circuit breaker here." If those breakers are all in the up position than it is most likely the breakers in your circuit panel.
May 04, 2012 | Baxter OV300E Stainless Steel Electric...
The cooking is not even when cooking small items
Often times this isn't something you want to attempt to rectify yourself. If you can find a way to deal with or adjust to this issue it will save you the cost of a repair visit. If the uneven bake is so severe that you cannot cook in the oven and you still wish to attempt repair by yourself you first need to identify which racks aren't cooking correctly and in which pattern is it uneven.
For example is the rack uneven in overall color from top to bottom, meaning are items on the top cooking to quickly where as the items on the bottom are uncooked? Or is the uneveness lateral where the center of a single tray is over/under cooking or the edges of a tray are over/under cooking.
Once you've identified your issues you need to locate your airflow louvers. They are usually located in the back right corner of this oven, it is where the hot air comes out of the heat exchanger chamber. You will notice there are gaps and there are fins. Adjusting the fins changes the way the air flows from side to side across your product, adjusting the gap changes how much hot air reaches the product.
Lets approach side to side uneveness first. To compensate for the center of a tray UNDER cooking take the metal fin lined up with that tray on the RIGHT side and slightly bend it to the left, directing air towards the center of the tray. If the center is over cooking bend it to the right, directing air away from the center of the tray.
For top to bottom uneveness you will need to loose the screws/bolts holding the fins in place and gently increase or decrease the gaps. Be careful here because if you loosen the screws too much the louver can slide out of place and make to large of a gap, potentially making things much worse. A good trick is to take a permanent marker and make a mark to where the louver was before you adjust it incase you need to put it back.
If a single tray is too light in relation to the other trays increase the gap, if it is too dark, decrease the gap. Do this for each tray that is coming out uneven. Make small adjustments and then do a bake to check the results, there may be a lot of trial and error involved.
If this seems overwhelming you're probably better off not attempting this because you can make things worse to the point where NOTHING comes out correctly, if that's the case call your local authorized service provider. Good luck!
Jan 03, 2011 | Baxter BXA2G Stainless Steel Gas Single...
The rack inside has stopped rotating
On top of the oven is a cover with 6 screws in it, loosen the screws and remove the cover. You will see two pulleys, most likely one of the pulleys are loose, try tightening the set screws, the one on the right can be tricky because the set screw is under the pulley. Good luck!
Dec 04, 2010 | Baxter OV300E Stainless Steel Electric...
When #9 program for Bagels is running , the temp drops 130 degrees before cycle is complete. also having to reset breaker several times
It's normal for the oven to drop temperature during the first 4 minutes of a bagel cycle, although the temperature should recover to 525 before the end of the bake. If your breaker keeps tripping you could have a blown heating element and should call your local authorized service provider, I wouldn't recommend attempting to repair this one on your own.
Sep 28, 2010 | Baxter OV300E Stainless Steel Electric...
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
Why bagels bake with no hole
If your bagels are turning into hockey pucks then most likely the steam isn't functioning on your oven. Make sure the water is turned on to the oven. If you still are getting no steam call an authorized service provider.
Dec 31, 2009 | Baxter OV300E Stainless Steel Electric...
When we turn the switch on, the light inside the oven goes on, but the touch pad does not come on, it comes on by itself after a while, or will shut off in the middle of cooking.
Control board defective. Before replacing the control board make sure that your incoming water pressure is no higher than 20 psi and that your door gaskets and fan seal is intact. Torn gaskets or a worn fan seal will allow steam to enter the burner compartment and damage your control board.
Sep 12, 2009 | Baxter OV300E Stainless Steel Electric...
Baxter OV300E Stainless Steel Electric Oven Logo
222 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
