Question about Toshiba Satellite A135-S4527 Notebook
I have a Toshiba Satellite A135-S4527 when I power the computer on the power button lights up on the front and stays lit and the hard drive button lights up for a second, but that is all I get. The lcd screen stays black and I can hear something running inside. I have tried a new drive and that didn't fix please help.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try to reseat the memory and then start the laptop back up.
  • Mike Gagnon
    Mike Gagnon May 11, 2010
    Have you tried to connect a remote monitor to see if you are getting picture?
    Guru:
  • 125 Answers
While turned off..You could take out the CD/DVD drive, HD, all the memmory(1 or 2 modules) and If you know how, even BlueTooth and modem and WLAN mini PCI/PCIE modules. Then try to start it. If you hear 2 beeps followed by any other numbers of beeps(2_x_x)...then you can be rather glad that your motherbord (still maybe!) works ok. If you hear other kombinations of numbers of beeps(1_x_x, 3_x_x or 4_x_x) then you may have problem with the motherboard :( .. in case you hear the 2_x_x beeps you have a memory problem..shut down the laptop...now put only one of the memory modules(if you have 2) and boot up...if you get the picture you should be able to see any BIOS POST warnings/error messages..if you still hear the 2_x_x beep comb. you have a memory problem..then you should buy a new memory! if you dont see any picture on the screen it could be the Graphics card problem or yet another indication to memory problem...if you get sure that the memory and the motherboard are ok then put in the components back in and boot after each to figure out witch part is problematic...
/BS
Posted on Mar 01, 2009
My Satellite A135-S4527 will not power up. I press the power botton it lights up in color blue (as normal) and the power on LED indicater lights up. This will stay on for appox 10 sec and goes off. No HDD...
check your power fan of your processor underneath on the laptop, possible cause is overheat, bring it to the shop for whole diagnosed.. if you continously used on that situation it might cause some problems to other parts due to overheating..
Aug 27, 2011 | Toshiba Satellite A135-S4527 Notebook
My cd/dvd player in my satellite a135-s4527 is not working.
you must go to www.gur.in website then go to registry tweaks on the left side then a window will refresh take a look on the right side choose restore missing cd drive. a registry button will pop up install it then restart the computer
Mar 30, 2011 | Toshiba Satellite A135-S4527 Notebook
The laptop needed charging. After charging, when the power button was pushed, the screen remained black. The power button is lit. What is the problem?
Sometimes when you reset the computer, that happens. disconnect the AC and count to 10. Plug back in. If that doesn't work...turn on from the power and that should automatically reset the screen.
Nov 27, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba A135-S2276 Black screen,only lights on front of laptop that are on are the power and battery light,fan work.i can here hard drive turning,DVD Driver light stays lit and will not open,Ive read...
i have encountered this problem before on many laptops and sometimes your monitor can just go bad or a piece of bad hardware in your laptop but in my case most of these problems are the monitor going bad. how old is this laptop
Nov 20, 2009 | Toshiba Satellite A135-S2276 Notebook
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Have you left a cd in drive? It could be trying to read a disk to boot from if thats how your boot order is set up. This is the first simplest thing to check.
Char S
May 24, 2009 | Toshiba Satellite A135-S4527 Notebook
My satellite A135-S4527 laptop doesn't recognize the dvd drive
You could try physically removing it and reseating it, if it still doesn't come up then its probably dead.
Jan 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
TOSHIBA LAPTOP SATELLITE A135-S4527 WON'T POWER UP
Not charging . . . And probably the power pin ... where the AC cord connects to thecomputer. That particular component is very fragile. The part torepair it runs between $ 5-$15 but the labor to repair it will costanywhere from $ 100-$250. It can be repaired by you if you are verycareful taking the system apart. Just pay attention to every detail ofyour dis-assembly. I also recommend you get one of these to stop the problem from happening a 2nd time.
Dec 14, 2008 | Toshiba Satellite A135-S4527 Notebook
All drives xp for Toshiba Satellite A135-S4527
Ok just to clear the question up... I you just installed a new HD in your laptop and have already downloaded your recovery cd that came with the pc then you are asking for the remaining drivers that you are missing... if so here is what you need to do. If you are not missing your internet driver go to www.driveragent.com this requires a yearly membership of I think 29$ This will scan your pc and give you the drivers to download. If you just installed a new HD and if you turn your computer on and get nothing this is because you did not install your recovery disk,,, if you do not have your recovery disk ONLY Toshiba can provide this and you can order it from them. I would also call Toshiba for your driver disk as well if you cannot get on the internet...
Jun 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
161 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
