Question about Faberware FCP280 Coffee Maker
Coffee pot fails to perk/prong becomes disconnected
This is the second coffee pot within two months to stop working.
we are frustrated, one of the smaller prongs seems to become loose
and pushes into the pot, therefor the connection is not complete.
This last time I used tweezers and pulled it out and was able to successfully complete connection. This is at best a temperary fix.
Any suggestions?
    Scholar:
  • 176 Answers
Hi you need a prong assm. callahanronald@att.net bobbyone
Posted on Aug 11, 2010
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
Why does my FCP412 farberware coffeepot not keep the coffee hot?
<br /> KEEP WARM ELEMENT<br /> <br /> <font size="3"><font face="Times New Roman"><span style="mso-spacerun: yes"> </span>The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. The KW element is $8.00 and $2.00 S/H. <a href="mailto:callahanronald@att.net">callahanronald@att.net</a></font></font><br /> Ron<br />
Aug 23, 2010 | Faberware FCP412 Coffee Maker
3 prong plugs becoming loose
Hi, You have a pot that was made in China. to fix the problem you have you have to replace the base. You can try to get one at Goodmens.com or Repair Shop.com. The China pot is very very inferior to the USA pots. I suggest buying a USA pot on eBay. The China pot is like owning a boat. Good luck . Ron
Jul 23, 2010 | Farberware FCP280 Stainless Steel...
WILL NOT PERK
check thermal fuse and element
Aug 16, 2009 | Mr. Coffee 2.3 oz. Coffee Grinder - White
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Aug 30, 2008 | Gevalia CM-500 12 Cup Coffee Maker
We bought a black&decker Spacemaker coffee maker last month and it has not worked properly but maybe a week. It seems to not want to flow correctly into the pot. We set it to come on and wake up to...
If the hole in the bottom of the basket isn't plugged, it sounds like the anti-drip feature isn't functioning properly. This is the series of levers that allow you to remove the pot while the coffee is perking without spraying liquid everywhere.
There is a vertical lever mounted at the back of the hollow where the pot goes, and the top end of that lever lines up with the spring-loaded lever that closes the bottom of the coffee basket. When the basket is in place without the pot, the bottom of the basket remains closed. When the pot is inserted it presses against the back lever and the series of contacts opens the valve covering the hole in the bottom of the basket, allowing the coffee to flow into the pot. If the sequence of contacts doesn't work the basket will overflow, and you get coffee and grounds everywhere.
Ensure all these parts align and are working properly. If there's a problem that can't be resolved, or parts are broken or missing, removing the spring-loaded lever from the basket will allow the coffee to flow into the pot. You will no longer be able to remove the pot while it is perking, but you'll have your morning coffee.
Apr 16, 2008 | Black & Decker SpaceMaker ODC150 Coffee...
8-cup Farberware electric coffee maker
Hi, I just posted this for the FCP412 model: here it goes again.
I've had the same problem, I went with a percolator since our water is hard and we calcify the heating element within about a year. Having the FCP-412 stop working has made me angry as well.
1st, I placed an order for a P04-303 thermostat. It seems to be the correct replacement but we'll see. You can find it here: http://www.goodmans.net/get_item_fa-p04-303_farberware-p04-303-thermostat-for-coffemaker-urn.htm
2nd, here is my 1 cent fix. Really, insert a penny under the thermostat. The delay that it takes to additionally heat the penny will increase the duration that the 1000 Watt element is on. You can experiment with other materials just make sure it isn't flammable (it's next to the element) and it is not too insulate (you want the thermostat to open the circuit some time after the start of the heating cycle (3-3:30 minutes).
Good luck. -david
Oct 09, 2007 | Faberware FCP280 Coffee Maker
Faberware FCP280 Coffee Maker Logo
97 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
