Question about Epiphone Les Paul 100 Electric Guitar
Minimal to no bridge
Used guitar.. sounded exelent when purchased,,played Loud & Hard for about a week ,, bridge pick-up (LEAD) started to "squeeeeal/ch ,, then went AWOL! ,, neck pick-up starting to squeeeeel/ch at mid level volume .
Need help fast!
    Scholar:
  • 109 Answers
Sounds like you have some microphonic pickups. Only thing to do is replace them. This would be caused by the guitar being hit against something or being dropped.
Posted on Jun 20, 2009
Tone knob and switch info
the switch, has three positions. Typically forward or up will be your neck (or rythm) pick ups, only and will work with one volume knob(usually top right as your looking at guitar), and one tone knob ( top left as your looking at the guitar). when the switch is in the far right or all the way down position, that will be the saddle (or lead) pick-ups. And that works with only one volume knob(bottom right as your looking at the guitar) and the corresponding tone knob. when the switch is in the middle position, botjh volume knobs work and both tone knobs work. You've gotta kinda play around with them to find whatever sound yopur looking for. and tone knobs are very subtle in their changes. good luck
Aug 26, 2014 | Epiphone Sheraton II Guitar Electric...
Tone changes in pearly gates pick up
What you describe sounds like pickups fighting against each other meaning, does this occur when using pickups individually or together? This is normal when using more than one pickup together, if it occurs in single mode, something is wired wrong. Another thing is, If using single, are you splitting coils? Individual coils wired wrong can do this, a bad pickup selector switch can also. A loose wire or fiber touching the tone pot capacitor or ground could also. A dead coil on a humbucker can as well. I'm guessing that you are using these in combo meaning a possible pickup selector switch may not be switching properly. The player's level of experience is also in my mind since, all of my guitars do the exact same ONLY when I use more than one pickup. I hardly ever use more than one at a time unless I'm playing a strat.
Mar 28, 2014 | Seymour Duncan ShPg1 Pearly Gates Pickup...
HELLO AND THANK YOU.... I LOVE MY 335...... BUT SOMETIMES ESPECIALLY WHEN PLAYING DOUBLESTOPS......THERE IS A RATTLEY, SPRINGY SOUND THAT ALMOST SOUNDS LIKE DISTORTION.... IRS NOT FRET...
Make sure amp sound is not hitting front of guitar straight on. Get a 2nd pair of hands and while you do a test strum have the other person use hand or hands and apply pressure to various places on the body(such as the bridge, headstock, sides, etc and see if any of those affect the sound. Very light strings are sometimes a problem.
Sep 25, 2017 | Gibson Guitar Gibson ES335 Dot Reissue...
I'm trying to wire passive pickups in my Schecter Tempest Hellraiser. The problem I'm having, is that there is no way to ground everything to the bridge. My pickups' wiring diagram (and my other guitars)...
If you have a metal bridge, then install a jumper from a convenient point to the rest of the grounds. These grounds help reduce hum pickup. If the guitar is working with no hum while using and handling it, don't sweat grounding the bridge... The purpose is REALLY to ground the strings which is where you will likely pick up hum when you touch them... you are an "antenna" picking up the noise from all the power lines, etc around you.
Apr 15, 2011 | Schecter Hellraiser Tempest Electric...
Buzzing noise when not playing
All amplifiers make a little bit of noise (hiss) but it is normally slight and drowned out by playing. However, assuming that this is not normal system hiss, here are a few simple steps to try and locate the source of the problem by process of elimination.
  1. SAFETY FIRST - a common cause of a humming or buzzing sound can be a lack of earth (grounding) on the mains supply. With a 240volt AC supply this hum will be at 50hz (in the UK) - frequency may vary in other countries but should be similar. Check the earth first because of risk of electric shock. Until you are satisfied that this is not the cause of the problem DO NOT touch any metal parts of the amp. Remove the mains lead and try a different one. Try plugging the amp into a different mains outlet socket (preferably one on a completely different circuit).
  2. Turn off other electrical equipment in the vicinity that may be causing interference. Move the amp a bit, try rotating it by 90 degrees to change relationship to things like mains electric cables in the floor.
  3. If you are using the line-out socket to give a feed to a mixer, slave amp or p.a. system unplug this. Sometimes double earthing (through the mains lead of your amp AND the mains lead of the MIXER / PA) will cause an 'earth loop' due to a different resistance at each end. Putting a DI box with an 'earth lift' in between may eliminate this problem. Alternatively there are little gadgets you can buy to do this (I found one intended for car audio systems on Amazon that works very well)
  4. Unplug any instrument leads - to eliminate possibilities of interference affecting cables, effects pedals or guitar pick-ups. Also unplug the foot-switch.
  5. If that stops it plug a lead in without a guitar on the other end - does the noise return? If yes change the lead. If no plug the guitar in.
  6. Try moving the guitar in relation to the amp (turn it around 90 or 180 degrees) - this will be pick-up to amp power supply interference.
  7. Does the sound get better or worse if you touch metal parts of the guitar with your hand? This may be a screening issue within the lead or the guitar itself.
  8. Try turning all the individual channel tone and gain controls to zero, turn off any effects on the amp panel. If that eliminates it only turn up the controls on channels that you are actually using.
Jan 30, 2011 | Marshall Amplification Marshall MG50FX 50...
Washburn guitar B and high E string sound real buzzy-tinny. am fretting it clean. It just started doing it. Any Help?
Probably time for string replacement !!! They do go bad...
Get a set and try the E string... if it fixes that one, change ALL the strings at one sitting, but do them one at a time and tune each as you go... this keeps the tension and minimizes the interaction when you do the final tuning.
Feb 27, 2010 | Washburn Idol Series WI18QT Electric...
Schecter Hellraiser C-1 question
Yes, you can install a Floyd Rose later, but it will cost you more to buy one later and install than if you were to purchase the Schecter with it already installed. A Floyd Rose bridge with trem can cost between $40.00 for a used one, to $80.00, or even higher, depending on the features you want. If you need it installed for you, you are looking at another $50.00 to $100.00 potentially.
If you are unable to purchase the one without the Floyd Rose bridge because the cost is a bit out of your reach, don't worry. Schecter C-1 guitars are well made and sound very nice, and you would still have a really nice guitar. I have owned two Schecters , and still kick myself for having sold them to "upgrade" to a Gibson Les Paul Standard. Just because it reads Gibson on the headstock, doesn't necessarily mean it's a better guitar. To prove that, check out reviews on Harmony Central sometime (www.harmony-central.com) and see how many people are displeased with their Gibsons, and how many are pleased with their Schecters.
But you don't have to worry about installation of a FL bridge later, as they fit exactly where the standard bridge and stop tailpiece are fitted.
I hope this helps.
Jul 16, 2009 | Schecter C 1 Hellraiser Electric Guitar
Neck and Middle pickups make little sound even with volume at max
Hi There!!
I am a gitarist myself too and firstly let me tell you u have purchased an excellent guitar to begin with!!
Now about the Neck\blues pickup.....If you say there is little sound this can be because of:-
1)Faulty bridge adjustment
2)There can be a problem also because of  the neck of the guitar being a bit bent in or around the place where u have the pick-ups though the chances of that are rare.
If there is no sound then please contact your dealer to change the piece....
Have a great time playing
Hoping this helped.Any help regarding the above steps , feel free to ask them.
See ya.
Dont forget to rate
Mar 14, 2009 | Yamaha Electric Guitar
Epiphone Les Paul 100 Electric Guitar Logo
134 people viewed this question
Top Epiphone Music Experts
Michial Gueffroy
Craig Butler
Craig Butler
Vito Vacirca Jr.
Are you an Epiphone Music Expert? Answer questions, earn points and help others
