Question about Kenmore 73952 Gas Dryer
Kenmore 70 sereis not drying
I have a gas Kenmore 70 seris dryer. About 6 yrs old. model number is 78702895, stock number-78702.
I checked the lint screen and outside to make sure it was clear of lint. The dsryer tumbles, but not heating up.
Should I check the heating element (not sure what or where that is) and what am I looking for. Is this an easy fix that anyone can do?
  • Anonymous Feb 09, 2009
    the dryer spins and but it doesn't heat up or dry the clothes
  • adolfo289 Feb 11, 2009
    My dryer was working just fine then suddenly stopped blowing hot air just cold air
  • 36 Answers
Before you call a technicia. check your thermal fuse which is located onn the back oif the dryer you will need to remove the back cover and it looks like has 2 terminals.. on can check itr with continuity..or unplugg your dryer...hook up the terminals...point is for em tyo make contactt do not hold it with your hand..and check to see if your igniter comes on.kenmore 70 sereis not drying - efdd9af.jpg
Posted on Feb 15, 2009
  • 979 Answers
Stephanie, your best bet is call a repairman. It sounds like the igniter ororifice is not getting the gas. If you are not sure what to look for, call for help. It will be worth it in the long run.
Posted on Feb 03, 2009
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore Soft Dry,
Try popping the lid and inspect the belt. I did one for friend. On his when the belt broke, the dryer quit. It has a built in safety switch. Sorry don't know the series. His was 15 years old plus...
Sep 13, 2009 | Kenmore 63942 Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Dryer not drying correctly
The coils are getting hot and won't open the gas valve. replace them dudes
291385a.jpgMore HERE
Mar 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore model #78702895 78702 front load natgas dryer : ignites and heats at beginning of cycle, then cools cycle continues without heat
replaced both the black coils on gas burner they will sometimes go bad after first heat cycle
Dec 05, 2008 | Dryers
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Kenmore 73952 Gas Dryer Logo
114 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
