Question about Canon imageRUNNER 5570 Copier
Make sure that all the covers are closed...
I checked all of the access covers, all are closed, but this message keeps comming up and the copier will not work. I can restart the copier and it will copy one job then it tests itself and this message comes up again. Does it need a sensor and where do I find them?
thank you !!
  • Canon Master
  • 990 Answers
Hello sir; Does screen display which door open? if not, you can try to open each door, use screw driver to actuact door switch, to find out which door switch defective.
Posted on Feb 03, 2009
Keeps saying cover is open/ please close the ADF cover
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
Mar 08, 2016 | Office Equipment & Supplies
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
My Toshiba e-studio 233 copier is giving the error message, "Close side cover." Opening any cover to close again changes the message to "Close x" where x is the part opened, until that...
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
Jun 27, 2011 | Office Equipment & Supplies
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
A message keeps saying print cartridge access door
check that sensor function while open / close upper cover, some time hook type sensor connector broken and need replacement. check also roller for possible stock paper.
Apr 04, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
I changed my ink cartridge, but the top cover won't close properly, and I keep getting a "cover open" error message---i am pretty sure the cartridge is in the right way. suggestions?
Lift the printer cover. There is a slot on the right side by the ink cartridges. Push the end of your little finger into the slot. Close the lid. I know this sounds lame, but it has helped me many times. It seems the latch will stick and this usually unsticks it.
Sep 25, 2009 | HP DeskJet 5650 InkJet Printer
Keep getting a U071 error message for cartge Y
Open the printer cover and check to make sure only one Yellow cartridge is installed. If so, try the following:
Remove each of the other cartridges, one at a time as necessary and see if the error message changes. Start by lifting the cover, then wait for the printhead to move to the left so you can access the cartridges inside. Pull out one of the other cartridges ( not Y) by pushing its front tab back then close the cover. Check the display, repeat as necessary. The error should have changed to U043 (bad or missing cartridge) once you remove the bad cartridge. When you replace it, the printer should work. My guess is the Magenta or Cyan cartridge is causing your error.
Apr 14, 2009 | Canon Office Equipment & Supplies
Copier Error Message
Their's a sensor that the Plug from the Finisher to the copier is not read, first make sure the "Attachment Kit' thats the part where when you push the Finisher to the Copier it Locks, their is a metal tab that sticks out and hits a "Sensor" if it doesn't hit the sensor it will keep telling you attach finsiher or close cover, if it's too annoying you can remove the finisher and unplug it from the rear. On the cover thier are alos sensors that need to be activated by tabs,MAKE SURE these are not missing if you do you need to order these items from "Koycera-Mita" Check those sensors
Mar 04, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
'Doc Cover open' error message
look for switch where the doc door closes and insert a piece of paper to trigger it, message should clear, adjust switch.
Aug 21, 2008 | Brother MFC 8440 All-In-One Laser Printer
Canon imageRUNNER 5570 Copier Logo
104 people viewed this question
old marine
old marine
