Question about LG WM2277H Front Load Washer
Drain problem I got 2005 LG tromm washer. When the drain processing, the drain pump motor is running(can hear the sound), but water is not drain. And display "OE". This is same situation as last time that replaced the dump motor to new one and works fine. Unfortunately, extra warranty was over last year so I want to fix this problem by myself. My question is dump is running but not work for drain..... Is this possible error ? Or any idea to solve this problem of not replacing motor ? Thank you.
  • taikoon35 Feb 03, 2009
    Do you mean.. inside of dump ?
  • taikoon35 Feb 09, 2009
    I checked inside of pump assembly, but thers is nothing inside.
    I cleaned up and run again but still noise and not drain.
    I think this pump motor had been damaged.
    Could you tell me where I can order online with good quality and price?
    Thank you.
    Genius:
  • 2,920 Answers
Check he pump and see if theres something stuck in it. you should be able to tell if theres a sock or somethingsyuck in it.
Posted on Feb 03, 2009
  • Ronnie Houston Feb 03, 2009
    check the pump before you do anything else
Why won't my LG washing machine pump out water?
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump
Sep 10, 2014 | LG WM2688HWM TROMM SteamWasher
Replacing the pump in my LG tromm
cheaper to check for a problem in the impeller first as the pump motor seldom fail but there are problems with items jamming the impeller
Oct 29, 2017 | LG WM-2277HW Front Load Washer
Washer wont drain showin IE
Sonia, you either have a failed drain pump, or something has bypassed the filter ( bobby pins are notorious for this ) and is jamming up the pump impeller. If you can set the washer to drain/spin and can hear the pump running, you most likely have a impeller that has broken off of the pump motor shaft and will need to be replaced. If you cannot hear the pump running, and can hear a slight humming noise, then there is something jammed in the pump. The pump can be removed and cleared of the possible foriegn object. I can provide instructions on pump removal if needed.
Apr 20, 2014 | LG Tromm Front Load Washer And Dryer Set
My lg tromm front load washer smells
Try this, It's involved but it worked on my Kenmore HE4tDrain the machinePull the filter (have a sheet pan, wet vac and towels handy, there's a lot of water)Disconnect the drain boot from the pump and tubDisconnect the pump drain hose (waste)Disconnect the pump electricalWash everything (not pump motor) in a 25% bleach solutionReassemble.Put 1 gal boiling water, 1 gal hot water and 1/2 cup bleach in washer compartment. check for leaksWash entire compartment with the bleach water and spin the drum time to time for 15 minutesAdd TechnoFresh (which claims to loosen gunk) to the powdered soap dispenser, through a bunch of rag towels in and run the machine on the hottest cycle.This process works well until machine is stinky again (about 6 months depending on bleach usage)BTW "the leave door open trick" only helps the door gasket and does not address the constant reservoir of fermenting water in the bottom of the machine
Feb 11, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I unscrewed the lower panel on the front and cleaned out the large black round cap on my LG Tromm Washer. I blow thru the small rubber hose and it sounds clear. I am still getting the OE when getting to...
As you know OE is drain error. you still have a drain problem and this could be because the pump impeller has a coin or similar jamming it, or it could be that the pump motor itself is failing. If the drain hose is clear and not kinked and the pump is working the machine should drain........Good luck....Nomess
May 27, 2010 | LG WM2688HWM TROMM SteamWasher
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Getting the OE error message on LG Tromm
Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Jan 18, 2009 | LG WM2688HWM TROMM SteamWasher
LG WM2277H Front Load Washer Logo
245 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
