Question about E-Machines eMachines Desktop PC
I heard the computer on but I do not see desktop
The monitor self diagnosis read check the cable or signal.
I did check but still not shown anythings on the monitor.
what I do?
  • 70 Answers
Here are some troubleshooting ideas:
1. If you have a LCD monitor, look for a source button on it and try pushing it (with the computer running) and see if it cycles between analog and digital.
2. If you don't have a source button, try the auto adjust button.
3. Try unplugging the power from the monitor for 30 seconds, then plug it back in, and turn the monitor back on.
If none of the above works, then it's possible that your video adapter isn't working.
If possible, try connecting another monitor to the computer and/or connect the monitor to another computer. (I know most people don't have a second PC, maybe a friend or neighbor can help with this.)
This will help you isolate where the problem lies. If the monitor works, then the video adapter may be bad. Depending on the model of the computer, you may be able to have a new one installed.
Hope this helps!
Posted on Feb 03, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
How do i get rid of "CHECK SIGNAL CABLE" on my 17" flatron wide monitor?
"Check Signal Cable" message is shown on the monitor only when their is disconnection between PC & monitor or if the cable is faulty. You can get rid of the message, which is built-in the monitor. Try changing the faulty cable.
Jun 28, 2011 | Dell Dimension 3000 PC Desktop
Monitor is on but screen is black. green light for switching it off/on does not do anything when pressed
Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website Thanks
Mar 01, 2010 | Dell E173FP 17" LCD Monitor
My LG l194wt monitor keeps shutting off.I am not sure if there is a reset button.After unpluging it will sometimes come back on
take the post(power on self test ) of a monitor connect power cable and disconnect signal cable see that no signal check signal cable massage comes then monitor is ok right cllick on desktop then properties screensaver -power -select -never
Feb 28, 2010 | Computers & Internet
My screen doesnt get a signal from the computer what could be wrong?
There could be three reasons for the same .
1. Loose signal cable: Check and reseat the VGA or DVI cable from the back of the system tower to the monitor.
2. Bad monitor : Disconnect the monitor cable from the back of the monitor check if the monitor displays anthing .
3. Bad video card : Try connecting an alternate monitor to check if the same is displaying anything on the screen.
Thanks for using Fixya
Jan 07, 2010 | Acer Aspire T310 PC Desktop
Computer powers up, but monitor shows a self test
Your video output is bad. Either the video card, or the onboard video built into the computer. You need to swap out the card or add a card to bypass the built in video port on your computer.
Thanks and please take a moment to rate as fixya.
Feb 11, 2009 | Gateway 550GR PC Desktop
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Monitor not working
If you have another cable to try that's a good bet. or buy one... you can always return it if that's not it. tho i suspect if you jiggled the cable and it worked thats the most likely suspect.
Sep 04, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
E-Machines eMachines Desktop PC Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
