Question about Refrigerators
WE HAVE A GE REFRIGERATOR THAT IS ONE YR OLD AND IT WILL NOT CRUSH ICE. WE'VE REPLACED THE ICE MAKER AND IT STILL WILL NOT CRUSH. IS THE SOLENOID OUT BEHIND THE ICEMAKER ARM IN THE FRIG WALL? GE MODEL PFSS6PKWASS
  • 1,543 Answers
You may be on the right track. Remove the ice bucket and check the square hole behind the ice bucket in the back wall of the freezer. You should be able to move the horizontal rod in it up and down with your finger. If not, it may be frozen in one position. If so, just warm the area a bit with a hair dryer to free it. Replace ice bucket and test. Another thing which may cause that is the ice auger itself may have separated from the drive shaft. (The icemaker itself has nothing to do with making "crushed" ice. It only makes cubes. The cubes are dispensed or crushed and dispensed at the front of the ice bucket using the auger and the metal parts there.) You might also want to verify that the long metal rod (which extends past the ice bucket and into that square hole) is able to move. (it is spring loaded)
Posted on Feb 03, 2009
Ice maker only produces crushed ice no cubes
Good Afternoon Gerald, thank you for your post!
I see that your Frigidaire refrigerator is only dispensing crushed ice not cubed ice. Your solenoid (which tells the dispenser crushed or cubed) might be frozen. You can defrost the solenoid by disabling power from it for at least one hour and then restoring power. If you continue to experience this issue you may need to have the solenoid replaced or the control panel and I would suggest having a professional technician out for proper repairs. Good luck with your refrigerator! -Matt
Apr 16, 2016 | Frigidaire Refrigerators
Icemaker dispenses crushed ice when you select cubed ice
GE has a problem with the flap on the door which lets the ice out , not closing due to a rusted solenoid behind the panel . If this flap does not close , frost will get inside the ice bin , not letting the bin flap open to let cubed use come thru, only crushed . You can defrost the ice bin front and replace the door flap solenoid easily . If this is the problem , repost about replaceing the flap solenoid for further instructions if needed .
Jul 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ice dispenser does not work and water dispenser works rarely.
the solenoid fell off, where does it go, it must regulate crush ice vs cubed ice. everything works except this
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
The button which selects cubes versus crushed controls a solenoid which engages/disengages the crusher. If the mechanisms which crush and push the ice from the chute are all clean, free of ice, etc., then the solenoid is not working. It either has loose/dirty connections or the solelnoid is bad.
May 05, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
ICE MAKER
test the solenoid voltage in auger assy. its a little tricky.
Jul 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
391 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
