Question about HP LaserJet P2015dn Printer
Low toner & paper jam light stays on. no paper jam seen. ink is new & still printer does not work
  • Anonymous Feb 06, 2009
    I have the same problem on a 4 month old printer. HP does not give that light combination as any type of error. I'm thinking it could be something catastrophic like a system board.
There is a problem with the HP 2015 printer. The symptoms you describe are a common fault requiring the printer to be returned to the HP repair centre.
Out of a batch of 40 2015 printers, we have had to return 9 so far for the same problem. 2 of the 9 have been back twice... The printers come back with new MAC addresses and this suggests that the main motherboard is being changed.
Posted on Feb 20, 2009
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Please help me with printer jam
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you get toner or ink on your clothing, wipe it off with a dry cloth and then launder the clothing in cold water.
Watch out for loose toner or ink on jammed paper, and do your best to avoid spilling it on yourself or the printer. If a little bit of loose toner or ink gets in the printer, though, it should clear after a few sheets are printed.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
IT KEEP SAYIN RMOVE PAPER JAM
    Remove any paper trays. Inspect them for wrinkled or damaged paper.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  2. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though
    1. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
May 02, 2010 | Office Equipment & Supplies
Paper feed is jamming ,I have not even gone through the original ink cartridges yet,so i haven`t done a lot printing
Things to do remove the papers jammed inside the printer.
  1. Please Turn off this Canon Pixma 2600 printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper or any piece of paper got trapped in the printer..
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Do it carefully with utmost care.
  8. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Before inserting the Toner or Catridge, please wipe the roller with cloth gently.
  10. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
See alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 16, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Printer will not work after paper jam fixed
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Jul 09, 2009 | Canon iP4500 Photo Printer
The screen keeps saying that there's a paper jam in my printer but i kept checking and checking, there's nothing in there. But the printer won't take in the new paper cuz of this invisible paper jam.
give this a try
alternative :
Jun 12, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Paper Jam lite is on ( no paper jam )
give this a try
alternative :
May 28, 2009 | Brother HL-2040 Laser Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
HP LaserJet P2015dn Printer Logo
611 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
