Question about Canon FAX-JX200
Fax comes out blank at the receiving fax machine.
When a fax is sent to another fax machine, it comes out blank. I tested the copy part, but it workes fine. At first it was sporadic, but now it happens with every fax I send.
  • VINODNIRWAL May 21, 2009
    FAX IS COMING BLANK, PLEASE HELP ME
  • VINODNIRWAL May 11, 2010
    thanks a lot
    President:
  • Canon Master
  • 990 Answers
Hello sir; I suggest you to replace a phone wire should be take care the problem.
Posted on Feb 03, 2009
Using HP 640 fax machine. Sent faxes are O.K., received faxes are blank?
are you sure you have ink in your fax machine. Try just making a copy.
Aug 15, 2014 | HP 640 Inkjet Fax Machine
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Outgoing fax was received as blank
Make sure that you sent the fax face down.
If all your faxes are sent blank, there may be a problem with the scanner. Try making a photo copy placing the page face down, if your copy comes out blank then the scanner is finished.
If your photocopy does not come out blank then the problem is on the other end and not your machine.
Thanks,
Pat
Aug 16, 2010 | Brother IntelliFax-2820 Laser Fax
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
This type of fax is "toy" buy a laser fax an get rid of all your problems
May 26, 2009 | Canon FAX-JX200
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Brother IntelliFAX 4100 shooting out blank sheets
The machine told you poor line quality. Try a different phone line to verify. Try it at a friends house to verify it. If you are using Vonage, that is the problem. I have Vonage and every fax I test with has some issues with poor line.
Aug 07, 2008 | Brother IntelliFAX 4100 Laser Fax
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Document sent is blank for recipient
Hi there check the machine scanner light by putting the original in the feeder and doing a copy. If the printout comes out OK then it either could be the other fax machine you are trying to send it to or you have a intermittent fault with your scanning lamp (Section).
You also must make sure that the original is text face down.
Hope this helps you
Thanks J
Jan 08, 2008 | Panasonic KX-FP121 Plain Paper Thermal Fax
Canon FAX-JX200 Logo
234 people viewed this question
old marine
old marine
