Question about Minolta EP4000/5000 CS/PRO Copier
Code c40 - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Expert
  • 1,326 Answers
I believe a c40 is the trans port sucation fan.... It is under the trans port belts. Did you try to reset the code? The Trouble rest botton is behind the display pannel control for brightness. Inside left side above the fixing unit.
Posted on Feb 07, 2009
Th-c40 universal remote codes, either ge or panasonic
There will be some features that may not work, its seldom a universal will work on all features
Oct 18, 2017 | Panasonic Televison & Video
No resistance. Already replaced alternator and resistor. I did the B+ and field wire test, and I get resistance that way. Also, the console flashes a 1 across the screen, that does not go away. Thoughts?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have done the proper test to rule out the alternator as the culprit. Not knowing which console you have on your unit, it sounds like the console is the problem. If you have the C40 type console, you can replace the PCB and PCBa to correct this issue. If you have the older style console, with red leds instead of white, you will need to find someone that can rebuild the console board. The board is no longer available in the older consoles. The following links will take you to the PCB and PCBa needed for the C40 console.
PCB for C40 Console SM27130 SPORTSMITH net
PCBA with LCD Screen for C40 Console SM40070 001 SPORTSMITH net
Oct 06, 2015 | Exercise & Fitness
How to fix the -C40 code
C40
Idle speed control valve (ISC valve)...
Will your bike start without the clutch pulled in? Sometimes aftermarket levers do not actuate the pin as needed.
Wouldn't hurt to pull apart and clean all electrical connectors, inc the ones under the airbox.
Dec 09, 2012 | 2007 Suzuki GSX-R 1000
Mu minolta is displaying c40 error
C40XX refer the exposure lamp,exposure lamp thermistor or thermofuse.Please read the correct error code:400,410,420.
Mar 13, 2011 | Minolta EP1030/1030F CS/PRO Copier
I have a GPS Navman c40/c60 and want to update maps etc, how do I do this? Karen.
The C40 is a "special" release for Australia, so I am presuming you are requesting information on Australian maps.
At present, the current map for Australia is 2009.
This link is for the Navman models you mentioned for Map information.
http://www.navmansupport.com.au/Maps/C%20Series.htm
Kind regards
Feb 14, 2010 | Uniden GPS
Epson Stylus C40 Plus printer cartridge replacement instructions
Hi
It sounds more like the printhead is blocked as if it either hasnt been used much or if the cartridges where taken out and the air has got to the nozzles, this would cause it to dry out and prevent the ink from flowing from the cartridge itself.
The C40 is pretty dated, so would probably cost more to repair than its worth. The S20 is about the closest match and is about £35 so might be worth looking at replacing.
Thanks
Taz
Oct 24, 2009 | Office Equipment & Supplies
INstalled a aftermarket Berringer clutch.
G'day Garrison , C40 is an idle air control(IAC) valve problem.Check all hoses to the valve.Check the valve wiring to the valve and to the ECU. ..Cheers.
May 14, 2009 | 2007 Suzuki GSX-R 1000
Need codec (?) so that I can playback video files taken with my Xacti C40
I use VLC from www.videolan.org that is a free and open source software.
May 12, 2008 | Sanyo Xacti C40 Camcorder
130 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
