Question about HP LaserJet P2015 Printer
Does not initiallize and caution and paper light blinking
When i turn the printer on, the lights comes on but it does not initalize.The caution and paper light keeps on blinking
  • HP Master
  • 4,338 Answers
Read this HP support page:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 07, 2009
Both lights are blinking, but paper is not drawn
Check to see if feed rollers are turning but not picking up the paper, if they are turning try clean with windex and see if dirt comes on the paper, if so either clean wheels reall good or the wheels need replacement.
Jul 23, 2014 | Epson Office Equipment & Supplies
In tvs speed 40 printer all led light are blinking
follow these steps
1) Press ST1+READY button together
2)Turn on the tvs speed 40plus passbook printer
3) The 4 LED will blink 4 times. Release the button ST1+READY immediately after 4 blinks
4)PRESS ST1 - ST1+READY+EJECT starts blinking
5)again PRESS ST1 - ST1+EJECT+ST2 starts blinking
6)again PRESS ST1 - ST1+EJECT starts blinking
7)again PRESS ST1 - ST1+EJECT starts blinking
8)again PRESS ST1 - READY+EJECT starts blinking
9) printer is READY wait and PUT PAPER.
10) The paper goes in and comes out 3 times. will take about 2 minutes.
11) Paper ejects automatically after printing.
12) turn off the printer and turn it on.
Jan 24, 2014 | Office Equipment & Supplies
Paper won't come out paper light blinks
I have a similar printer. Sometimes the bottom paper tray gets stuck or caught. Make sure the printer is on a flat surface.
1. Turn off the printer.
2. Pull the paper tray all the way out.
3. Take out all the paper and then place the tray back in.
4. Turn the machine on and let it try to print without paper.
5. When the light comes on add paper hit the button and you should be good to go.
Jul 26, 2011 | Brother HL 2140 Laser Printer
Red blinking light
Hi, this is not a cartridge related problem. As you have written, it is related to the paper misfeed. When removing any future paper misfeeds, always take extra caution as not to destroy the paper sensor. If it jammed near the paper tray area, first open the right cover to see the paper, the try to pull it slowly till it comes out. Never try to force it out as you may tear a small piece which will show you that a misfeed is still on. If it does tear, carefully remove it until its out. If it jams on the fusing unit, release the side levers on the copier or turn the green rotating lever on the front which appears when front cover is open until it ejects it out.
If you are sure there is no jammed paper, make sure the spring on right side of fusing unit, where there is a sensor is retracted to its position. Good luck pal.
Jun 05, 2010 | Sharp AL 1631 Copier
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Paper light blinking, paper tray full, won't print
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
Sep 04, 2009 | Brother HL 5140 Laser Printer
My laserjet 2550 won't print. The light beside the triangle is blinking but I don't know what that means.
Hello there,
What is the color of the blinking light? Is it red or green? If its red, then there must be a cartridge issue or paper jam. Did you load the paper correctly? Also, please try to do a reset of the printer.
Aug 03, 2009 | HP LaserJet 2550N Photo Printer
I have a hp 1150 printer after initiallizing all 3 lights r on. What might b the problem.
I went to the HP web site. If the three lights are blinking in turn, the printer is still trying to initialize or clear a previous job. If all of the lights are on but not blinking, you should turn off the printer and then turn it back on. If that doesn't help, turn it off and unplug it for 5 minutes before plugging it back in and turning it on. If the printer still gives an error, contact HP. If the three lights are blinking simultaneously, you have a memory error. However, the DIMMs are not replaceable on the HP 1150, if I understand correctly.
I hope this helps. (Please note: on many USB printers, it is useful to unplug the USB cable from both the printer and the computer, as well as unplugging the power cable when attempting to clear an error.)
Jul 27, 2009 | HP LaserJet 1150 Printer
Paper light continually flashes won't print
when you lift the cover on the back of the printer there is a thin plastic sensor very delicate normally black in colour which detects whether there is paper in the tray or not.that sensor is slightly moved from its orignal position or broken , so this problem is coming.
Sep 18, 2008 | HP LaserJet 4L Printer
Blinking lights
this means your printer wast pad is full this is now oyu reset your printer but make sure you have put new pads in 1st and dont for get to rate plz
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
Sep 11, 2008 | Epson Stylus 2200 InkJet Photo Printer
HP LaserJet P2015 Printer Logo
115 people viewed this question
Ben Johnson
