Question about GE WBSR3140DW Top Load Washer
Kenmore washer 110.92292100..Washer Timer Control Knob is broken, just spins around..don't know how to get it off to replace it. Need a replacement part. Called a repair man, he wants $75.00 just to come over and look at it..Help! Char Control knob just spins will not work pushed in or out.
  • 1 more comment
  • strumming12 Apr 07, 2009
    My kenmore Model 110.82873820 is doing the same thing.
  • Anonymous May 12, 2009
    Kenmore 110.82891110 - The knob spins and will not turn the stem. Is the knob the only thing that controls the turning of the stem? The screw on part of the knob we have is metal not plastic and appears to be in excellent condition. The threads do not appear to be stripped. The timer appears to be in working order so that is not the problem for us.
  • strumming12 May 11, 2010
    I ordered the knob but cannot figure out how to take the old one off?
    I looks like it should just spin off but it is not?
  • 1,214 Answers
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Posted on Feb 03, 2009
  • LindaD1 Nov 12, 2010
    I discovered today that the knob was loose because I had inadvertently loosened it while cleaning and perhaps this was also from years of vibration. All I had to do was to turn the knob CW until it was able to turn the dial again... wahoo!!!
I have a very old kenmore washer, model 110.82984700, doing great until yesterday turned on and filled and now only makes clicking noise when turns on, nothing else. Is the cycle/timing knob need to be...
Quite possibly - assuming you can get a replacement unit.
Consult a local (or closest) representative to see if spares are still available, but don't hold your breath.
Jun 04, 2011 | Kenmore Washer Timer Control Knob 3362624...
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Washer not spinning - not timer
I have a Kenmore 80 series mode #2289400. It will wash but will not drain and spin. I have turned the knob to a different spin cycle put it won't spin. I have drained the water out of the tub thru the drain pipe so it's not plugged. When it's ready to spin and it making no noice. Any help would be great.
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer not spinning
my ge top load washer washes but wont spin at end of cycle to ring the clothes out. if i mess around with the switch or motor wire connections it starts to spin with some help
Jan 05, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
GE WBSR3140DW Top Load Washer Logo
1,177 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
