FixYa.com
Tags:
IBM WaveRunner 7845 Network Terminator Extended  Modem
ISDN to non-ISDN Connection -- Questions
By Ranny - usenet poster
I've rtfm'd (the FAQ, honest), but I just don't see the information.
Questions:
1. What happens in an attempted connection (dialed) from an NT1 port
terminal to a distant POTS number with a conventional modem? If this is
feasible, what's the flow control, speed, etc. at the distant end? Is
that determined by the CO? What rules apply?
2. Similar question regarding a POTS-initiated call.
What point am I missing?
Thanks, folks.
| Signature? I don't need no steenkeen'
| signature!
| awww, Arnold Shore
| Annapolis, MD
| (410) 849-8721
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Helpful (85)
jessie25
jessie25 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I think that the connection can be made both ways, but the person to talk
to at least initially is Ann McHenry @ 301 236-3093 for Bell Atlantic Modem
Pools.
Regards,
Joe McGraw ()
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
: Tilman Schmidt < <snip : Bell Atlantic has installed modem
: pools at larger CO's which are accessible from among other things the D
: channel of an ISDN line.
Interesting, but who and how does that modem pool serve? Do I (an ISDN
user) connect through that (remote CO) pool to a POTS modem user? If so,
how does that POTS modem user initiate the call to me?
What's a good source of info on that service? Someone at Bell Atl? The
Bellcore pkg doesn't address it.
| signature!
| awww, Arnold Shore
| Annapolis, MD
| (410) 849-8721
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
I don't know about other areas, but Bell Atlantic has installed modem
pools at larger CO's which are accessible from among other things the D channel
of an ISDN line.
Regards,
Joe McGraw ()
Solution #4
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
If you were thinking of a connection between an ISDN number and a
POTS number that would look like a data connection on the ISDN side
- no way. Only voice connections can cross the border between ISDN
and POTS. Theoretically, telcos could have installed banks of
modems to convert data calls between the two networks, just as they
installed banks of A/D-D/A converters to convert voice calls, but
that would be much more expensive because of the variety and
ongoing evolution of modems. The demand is probably just not big
enough to justify the effort.
So the only option you have is to make a voice connection and
perform the modem functions on the ISDN end with your own
equipment. There are two ways to do this:
1. You hook a real modem to an a/b Terminal Adapter. The two
modems will never know that the voice connection between
them actually goes through ISDN.
2. You do the modulation/demodulation digitally by applying the
appropriate algorithms to analyze the digitized modem signal
you get out of the ISDN end of the connection, and synthesize
digitally the waveform that the modem on the POTS end will
understand, after the D/A conversion done for you by the ISDN
to POTS gateway. This is what ISDN cards like the IBM
WaveRunner do. It is of course much more difficult to
implement and needs considerable processing power on the ISDN
card, but has the potential for better transmission quality
because you get rid of one A/D-D/A conversion (in the a/b
Adapter).
HTH
Tilman
Tilman Schmidt Phone: +49 221 8299 275
Sema Group Deutschland GmbH Fax: +49 221 8299 266
Siegburger Str. 215, 50679 Koeln, Germany E-Mail:
Solution #5
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
There are a number of cases.
1. If you call from an ISDN telephone the call will be connected and you will
hear the modem beep in your ear.
2. If you have a modem connected to an analog port on an ISDN TA or if you
have a digital modem (a la IBM Waverunner) you will get a connection and the
modems will communicate if they are compatible.
3. If you call using an ISDN circuit mode data device you will not be able to
complete the call because the bearer services are not compatible.
1. If you call from an analog phone the call will be connected an you will
2. If you call from a modem you will get a connection and the modems will
Did I understand you question?
Bob Larribeau
Consultant
San Francisco
Solution #6
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
In note <31mtl6$@news1.digex.net writes:
Normal... A 14,400bps modem would get... 14,400 bps 8-). Flow control,
RTS/CTS is normal... Basically it acts like a normal line (except probably
somewhat cleaner than man since the coax is eliminated or at least greatly
reduced.) Oh.. spent too much time in alt.radio.cb and ham 8-)... I meant the
copper 8-).
Can you Help with these Modems problems?
Modems
can't connect to internet
i need the corrent ip address... Answer This...
Modems
HP Pavilion dv1000
i formatted my laptop.. since... Answer This...
Modems
test stam14
test stam14 Answer This...
Modems
integers powers roots
does 2?+¹=2?*2¹ Answer This...
Modems
moden of huawei ETS 2288 WLL
kindly show me that where from... Answer This...
Repair Service
Find Modem Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
