Question about HP LaserJet 4350 Printer
Paper trays If our HP laserjet 4350 runs out of draft paper in tray 4 it automatically starts to pull paper from out letter head tray which is tray 2. is there a way to prevent this? I would like it to stop printing when tray 4 runs out of paper.
    Genius:
  • 2,120 Answers
You will find the answer in Printer properties.
I think you have to turn off auto select.
Posted on Feb 04, 2009
How do you manually feed legal paper into a HP laserjet 4 plus (model 2037A)? It only has a letter paper tray. I inherited it without a service manual
The LaserJet 4 plus I have worked with had a paper tray that was adjustable for letter or legal. If yours is not, there should be a door on the front of the printer that will pull down at the top, and is hinged on the bottom. Open the door, you will be able to extend the "paper tray" and put a small amount of legal sheets on it. Go to the menu and tell it to print to this paper tray, I believe it is paper tray one.
Aug 02, 2013 | HP LaserJet 4 plus Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
I have HP laser jet 4350dtn heavy duty printer. It is attached with thye network point. And the configuration is done on the server. Then for the client machines I install via from the server since it is...
1 of 2 things. Either the paper type and size is not set right in the printer menu for tray 2. or the physical setting in the tray are not exactly on letter. The printer is looking for letter paper and does not see it in tray 2. If you load tray 1 with paper and press the green button my guess is it will use that paer and tray. First chack to make sure the setting in the tray are exactly on letter, it uses that and little fingers on the left side to tell the printer there is letter paper in the tray.
Jan 13, 2011 | HP LaserJet 4350 Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
Paper Available does not include legal (only letter and A4). Tried to go into the Advanced Properties - no legal available? The printer recognizes the legal tray but the laptop does not.
Try setting the paper size in the printer settings.
Click Printer and Faxes then right click on the HP Laserjet 4350 and click on Properties, then Device Settings tab and click on the down arrow and click on Tray 1 or 2 that has the Letter Paper installed and select the Letter paper size. Then click OK.
This paper tray is now configured for Letter paper.
Jun 09, 2010 | HP LaserJet 4350 Printer
Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
Nov 30, 2007 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
198 people viewed this question
Ben Johnson
