Question about RCA P52926 52" Rear Projection Television
The front screen cover
I seem to have a bug inside the screen on my tv..i was wondering if the screen cover pops off to get the bug out?
    Problem Solver:
  • 9 Answers
The speaker cover just pulls off, there are 4 screws holding the screen on, take them out and the screen should lift off. But be careful, there are wires attached to it, so don't let it drop.
Posted on Aug 29, 2009
Spot in tv
The spot may be from debris inside the chamber of the TV box. A bug, dust speck, or other material can attach to the inside screen or on a color tube inside of the unit. Do not touch the inside of the Front Screen as it has a special coating and you could damage the screen permanently. Avoid washing with water or sprays that can enter the frame of the screen. Use a cloth with cleaner applied to it and wipe clean, then dry with a soft rag or paper towel.
Mar 17, 2014 | Hitachi 50VS69 50" Projection HDTV
Mitsubishi WS-65819__Convergence bows at top and bottom of the screen. Pops in and out and if I take off the front speaker grills and Picture tube cover and place a fan in front of it to keep it cool, it...
Correct, convergence output chips are getting heated and causing problem. Replace them to solve tv issue.
Also check dry solder connection nearby these chips, resoldering these solder connections will cure dry solder joints problem as well.
Dec 24, 2010 | Mitsubishi WS-65819 TV
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
Bug parts or debris between screen cover and screen.
All from the front. Pull off the bottom speaker grill. No screws just pull straight back. There are rubber post that hold it. Next remove the screws on the bottom of the screen assembly. With them off you should be able to slide the screen assembly up about 1-2 inches and take off. This model does have auto convergence so the screen may have wires hooked to the back. With the power off disconnect the leads before setting the screen assembly down. Cleaning should be with a plastic cleaner not windex. If you do have to remove screen parts it's fairly obvious. Be sure to reassemble the same order and make sure you have help these parts are delicate when separate.
Mar 22, 2009 | Hitachi 50UX57B 50" Rear Projection...
Front screen
look on back of tv there is 25 screws remove them and the 5 on bootom in front of tv.
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
Front screen
Hi, much easier to access the front screens (there are 2 sandwiched together) by removing the top back cover, be prepared for lots of screws and when you get down to the last 2-3 screws get some help, on the inside of the back cover is a large mirror, some are made of mylar, do NOT clean or even touch a mylar mirror, the others are made of real glass and the back will be much heavier than you think (and very expensive if you break it)once the back is removed you should have access to the bug, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Removing and cleaning the screen on a 65" rear projection tv
You can remove the screen, take the speaker cover off in the front you sould be able to see the screws that hold the screen on the bottom remove the screws and unplug the wire the goes to the screen fron the tv, you need two people one on each side just pop each side up about an inch and pull it off,
Jan 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Bugs in my tv
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
81 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
