Question about Canon PIXMA MP210 Photo All-In-One Printer
Printer still won't work after refilled cartridges
I had my black and colored ink cartridges refilled and my printer still shows that it is empty. What should I do.
  • jazztiffa Feb 05, 2009
    im having the same problem to jennine. did you end up fixing yours?
    Problem Solver:
  • 9 Answers
Let me know the printer company name..........................
try this............: align your catridges.
wash the both catridges with water & safely rub with soft cloth.
Posted on Feb 03, 2009
When I put a new Black ink in my Canon MX452 it shows my black as empty
Hi
if the black cartridge is genuine and new...take it back. It is faulty.
If the cartridge is refilled or compatible...hold the STOP button for 6+ seconds to disable ink monitoring. This should clear the 'empty' error and the printer should work again.
good luck!
May 17, 2014 | Canon PIXMA Office Equipment & Supplies
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
I am trying to scan a document, however the black ink is empty. It only shows the error message that I should refill my ink. Shouldn't I still be able to scan documents?
Must be using PG830 or PG40 50?
For Canon, if either color or black cartridge is empty or out of ink, "Scanner" doesn't work.
That's why your scanner is not properly working.
It's all connected... That's Canon.
Are you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needles are needed.
It's not only easy to refill, you can have quality printing.
Check out my youtube video, will find how easy refill can be done.
Apr 20, 2011 | Canon MP490 InkJet Printer
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
shows empty cartridges but it will printing.
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Refilling cartridges
For that printer: there are 4 color and 4 black cartridges BESIDES the #31 photo cartridge. Lexmark has made it so you MUST either, throw away or send to them, the 36 and 37, the 36XL and 37XL. The printer will never again recognize them after they are removed from the printer...
However, the 36XLA and 37XLA AND the 36A and 37A as well as the 31 Photo may be removed from the printer, refilled, and reinstalled.
I have seen some forums that say you can but a piece of BLACK tape, across the bottom row of contacts on the non-refillable cartridges....I believe there are 4 to 7 contacts across the bottom row only.....and the printer will still give you a message that it needs ink.....but it WILL print. I have not tested this theory yet though. I have just gotten the first message saying my black ink is very low.
Hope this helps and I think Lexmark Corporation Sucks for tricking people like this. (This printer comes with the NON refillable cartridges as default, but I did NOT see in the documentation that it couldn't be refilled. Nasty people........:(
Good Luck~~! mstipps@yahoo.com
Jun 01, 2009 | Lexmark X3650 Printer
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Color Ink Cartridge
the support of both the cartridges is required to get a printout in this printer so if it is showing empty get it refilled properly to start printing again or buy new one.
Feb 23, 2008 | Canon MultiPASS C555 InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
198 people viewed this question
old marine
old marine
