Question about Logitech R-20 Computer Speakers
Ihave a new vision computer that came with the logitech speakers. I have 3 plugins side by side at bottom of back of computer. I plugged in the green to the green but I do not get sound. Please help
  • 58 Answers
May be problem is not with the speakers if you connected properly.
If you connected power cable properly and LED is on, Then there may be a problem with the drivers.
Check if the audio drivers are installed or not. If not install the drivres by using the mother board CD.
Hope this helps.
Posted on Feb 03, 2009
I can only listen sound from the 2 front speakers while i have logitech x-530 5.1. My mobo has 3 colours at audio(pink.greeen.blue) and my speakers have green.pink.black. I only plugged green tho. Can i...
plug them all in pink/pink green/green blue/black
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Dec 28, 2010 | Logitech X-530 Computer Speakers
HOW DO I HOOK THIS LOGITECH TO MY COMPUTER
Look on the back of your computer for GREEN and PINK and BLUE sockets.
PINK - plug a microphone into this socket.
BLUE -- plug an audio-device (CD-player, iPod, cassette deck) into this "audio-in" port
GREEN - plug your speakers into this "audio-out" port.
Connect the speakers to an AC power-outlet.
Oct 19, 2010 | Logitech X-530 Computer Speakers
How do i connect new speakers to my HP2009 PC?
Plug 1/8th plug (green or black) from speakers into the green jack on pc.
Jun 29, 2009 | HP (ZD929AA) Computer Speakers
No sounds on my speakers
1. Power to the speakers (make sure they are plugged in!)
2. Make sure the speaker line is plugged into the correct port on your sound card. The connector should be green and possible the port will be green to.
3. Double click the little speaker in the bottom right of the screen (assuming you are using XP/VISTA) and make sure nothing is muted.
Post back with your results.
Jun 03, 2009 | Logitech R-10 Computer Speakers
Logitech speakers :(
Hi and welcome to FixYa,
Initially, I feel uncomfortable cutting the 3 plugs, splicing them together and soldering to just one plug. What I have in mind is to use 3 barrel jacks (use stereo, the image is for a mono), splice them together and connect a single 3.5 mm plug, homemade splitter.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Logitech X-530 Computer Speakers
Logitech S-220 Speakers
did you plugin the speakers in the green input? back of your computer?
try to go to controlpanel, and then sounds and check your settings.
good luck
Oct 09, 2008 | Logitech Audio Players & Recorders
Conection
Find the Audio card of you computer. Mostly audio card jack had label line out or audio. Also audio out jack was light green in color.
Jun 17, 2008 | Boka 81000 Computer Speakers
Logitech z-540 no sound
Here are a few basic steps. they seem abit logical but just have a double check on them.
1. Check that you speakers are plugged in.
2. That the wire going into the back of the computer is going into the green imput (that is for the speaker sound to come out)
3 If you have a combination of speakers make sure they are all wired properly.
If your sure all the wiring is right. Check to see if the volume on the status bar at the bottom left of your desktop is turned on. This will be a small speaker double click on it, check to see if the volume is turned on.
If all this is correct it may be a driver problem. If so come back and let me know and I will guide you through the drive troubleshooting for this.
Sean
Dec 10, 2007 | Logitech Z-540 Computer Speakers
No sound on Vista
try out by installing he audio drivers by using motherboard CD and check whether you have correctly plugged the speakers cables into their respective plugins.
Oct 12, 2007 | Logitech Z-2300 Computer Speakers
Logitech R-20 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
