Question about Galaxy Radios DX-95T Base CB Radio
Galaxt 95t when i key the mic i get a squealing noise
Check that all the screws that hold the chassis together are tight so that there is a good connection between all the pieces. I've seen this same problem especially on moble radios as the screws vibrate loose.
Posted on May 16, 2009
  • 170 Answers
Maybe check to see if the talkback is turned on.If so, turn it ouff you mght be getting feedback because the mic is too close to radio. Try external speaker, or a nise canceling mic (rk56,or astetic 623),
Also this is a realitive high power radio, so make sure you have a good match on the antenna and you arent starving the radio for power.
Wish you where more specific about the sqeal if it was feedback or echo was acting up. Alos built in roger beet makes tehe short squueal when unkeying mic.
Posted on Feb 05, 2009
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
My radio shows power but its not transmitting out and shows only5 watts on a meter
Don't rely on that meter. use a good Known external meter to check.. make sure your mode switch is on am... not any other mode. also try a different mic. New mics start --RK56's$38.99/Stock mics$6.99...
Mar 07, 2011 | Galaxy Radios DX-95T Base CB Radio
I have a uniden grant and i have wired a galaxy power desk mic with rogger beep when ever i key it up it squeals was wondering is there a way to fix that
yeah your mic gain is way too high. You can either turn off talk back if you can, or turn the gain down. Depending on how loud the talk back is, your audio may suffer. If that is the case, you will not be able to run that mic. Get an RK-56 or a Skythumper mic. They are noise canceling. You will get no squeal with that mic, and it will sound awesome.
If you really want a roger beep, take it to a tech and them install one.
Oct 23, 2010 | Galaxy Radios DX-66V Base CB Radio
How can i disconnect the talk back on a connex 3300 plus? pleasa be specific on directions. thanks
in older connex 3300's you cannot disable the talk back. Its part of the audio chain. If you disable the talk back you will loose your audio. There are 2 things you can do.
Hook a relay to the speaker so that when the radio key's id disconnects the speaker. (Big pain, not worth the trouble.)
The other will not disable the talk back but it will stop any squealing.
Use a noise canceling mic. An RK-56 will work great. You will get no squealing with that mic.
Oct 19, 2010 | Connex 3300 240-Channels Base CB Radio
Talkback sqeels when it decides to work!
the squealing you are referring to is usually due to to a disabled automatic modulation control circuit.
one or more dry solder connections could cause the intermittent operation.
May 22, 2009 | Galaxy Radios DX-95T Base CB Radio
OK I remember a similar problem with a connex radio. It seems the driver's fm radio speakers where picking up some signal even with the fm radio off. Shortening the speaker wires helped some, also make sure you don't have any wire or coax coiled up anywhere. Thats about all I remember, hope this helps.
Feb 05, 2009 | Galaxy Radios DX-95T Base CB Radio
Galaxy 95T
check SWR's check to make sure ALL coax connectors are tight. and if still doing it. may be loose connection in board. but the export style radios go crazy like that when coax is loose or have bad grounds. due to there floating ground circuit design. there not the same as a cobra were its case is ground.
Feb 03, 2009 | Galaxy Radios DX-95T Base CB Radio
CB Squeal When Transmitting
I believe the coiled coax may indeed be the problem. To check, try a temporary rerouting of the cable which eliminates the coils. Dave g.
Dec 20, 2008 | Galaxy Radios DX-44V 40-Channels Base CB...
Squealing Noise
Some radios use the push to talk switch in the microphone to ground the receiver section when transmitting instead of a relay in the radio. There may be a problem with that switch, or the switching circuit in the radio itself.
If you have a PA switch make sure it is in the off position, if on it will squeal like a pig!
Oct 17, 2008 | Connex 4600 Base CB Radio
Galaxy Radios DX-95T Base CB Radio Logo
190 people viewed this question
Top Galaxy Radios Radio Communications Experts
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
