Question about LG Televison & Video
No picture plugged in HDMI cable to the tv ,back to the reciever to the OUT HDMI plug in.. From my cable box, I plugged in an HDMI cable to the IN on my reciever I also went to menu and clicked on HDMI connection. I get no picture. I also reversed the cables and still nothing. Randy
Yes I got the problem fixed. When we got the new cable box you have to call in to Time Warner cable and they have to program the new box.
Thanks for the reply
Randy Deer
Posted on Feb 04, 2009
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
How do I connect my cable box with an HDMI cable? I can see where the cable connects, but which input do I choose on the device menu?
It is up to you use the HDMI input so you can select it from your remote, notice one may be an output but the cable box hdmi device will plug into the box and the other end plugs into the hdmi cable connector. then select from your remote or your tv that hdmi connection to recieve signal, and set the remote to work with the TV and the Cable box, if you need more help post here and if this was helpful please rate.
Jul 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
Can't get video via HDMI
Go to here
will tell you how setting Video output
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Says no signal when switched to hdmi when there is one.
My best guess would be that the resolution settings on your reciever are set too high(It's putting out an HD signal the TV can't display) Plug in through Composite or component the the box and resolve this through you Cable box's menu, then reconnect the HDMI cable.
Dec 23, 2006 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
98 people viewed this question
Computer Repairing
Computer Repairing
