Question about Oregon Scientific FM Weather Projection Clock with Self-Setting Atomc Time and Vibrating Pillow Speaker
I have a model BAR338P Weather Station that does not see the remote (Outside )temperature unit. What can I do to make it work? I reset it afer installing the batteries. It flashes every few seconds but it is not recognized by the base unit. I noticed that the remote unit is set on Channel 1 (should I change it to 2 or 3?).
3 Suggested Answers
  • 1114 Answers
SOURCE: I cannot open the remote sensor for my Oregon Scientific PSM06AR.
I believe the back of the sensor slides open. There may be a faint arrow on the back that indicates the direction in which you push.
My unit took well over 24 hrs to reset. I think it has to do with the position of the satellite in relation to where you live.
Posted on Jun 29, 2009
SOURCE: I have changed the batteries
You will need to take the battery out of the receiving unit first (taking the battery out of place in the clock) and then put it back. This is just an issue of what battery is inserted first. Your outside temp will read again
Posted on Nov 16, 2010
My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Dec 17, 2016 | Measuring Tools & Sensors
I have a new weathr station and can not get the outside temp. to display what can I do?
I assume it is a wireless station. If so, there is a procedure to go through to get the temperature sender and the base station to sync up and work. You need to check your owners manual to get the exact procedure for your unit. On my station, I have to remove the battery from the base station, let it power up and within 5 minutes, install the battery in the remote station(s) (temperature, rain gauge, wind gauge, etc.). Also, you must keep the remote station within a certain range for the base to get a good signal. Probably 25 feet, but the owners manual will have the right number. Also, use new batteries.
Aug 02, 2016 | Oregon Scientific WMR86 - Backyard Pro...
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Model 00822A2. Why doesn't inside unit show outside temperature?
If you tried removing and replacing batteries, you should bear in mind that all batteries should be removed to "reset" the station then batteries should be installed in the outside sender first and time allowed for it to begin transmitting temperature. Next, batteries should be installed in the receiver and you should begin to read outside temperature.
Nov 24, 2015 | Acu-Rite Measuring Tools & Sensors
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Jul 01, 2014 | Acu-Rite Acurite Wireless Weather...
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Aug 05, 2012 | Bushnell Measuring Tools & Sensors
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
Oregon Scientific FM Weather Projection Clock with Self-Setting Atomc Time and Vibrating Pillow Speaker Logo
283 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
