Question about Hitachi 42PD3000 42 in. Plasma Television
Cant get hitachi 42pd3000e to switch on - Hitachi 42PD3000 42 in. Plasma Television
No sound on tv
check the main setting for correct output settings.
Mar 22, 2014 | Televison & Video
Hi, My dvd has got stuck in my hitachi hit19wdvbdvd player the eject button won't work.
unfortunately, if the drive is stuck, the only way to retrieve your disk would be to take the unit apart. Be careful though as this will void any warrenty. Make sure the set is switched off and unplugged before attempting this, be careful as even when switched off, some tvs can still hold a lot of voltage.
May 05, 2011 | Hitachi Televison & Video
I recently purchased a hitachi 1251e and have put a 2gb sd card in and now i cant take any pictures and the screen shows "media error". please help me, what do i need to do??!!
Hello!!
Firstly switch off the camera.
Press and hold the ok button and turn the camera on and off for few times whilst keeping this button depressed .
Dec 02, 2010 | Hitachi Cameras
My hitachi digtal camera hdc-570ap not switching on red led blinking other buttons not responding
You probably aren't using high power Triple A batteries. Try using Duracell Ultra high power batteries instead.
Apr 04, 2010 | Hitachi Cameras
Switch on but no lights on front of tv looks like switch fault
LG PLASMA TV LGE PDP 030826
WHEN TURNS ON ,THE BRIGHTNESS IS DIM THA WE CANT SEE THE PICTURE CLEARLY.WE HAD REPLACED PCB.IT WAS O.K
BUT AFTER 15DAYS THE SAME PROBLEM ARISED.AGAIN I HAD REPLACED THE PCB BUT I CANT GET THE BRIGHTNESS.
IF U R HAVING ANY SOLUTION PL.GUIDE ME.
SANJAY JAIN
RAIPUR (C.G.)
INDIA
e-mail: onida.bhavyainnovation@live.com
Jan 16, 2010 | Hitachi 42 in. Plasma TV
Hi, My Hitachi Laptop has WIFI system, but it does not work.
If you switch on WiFi and a light does not come on, then your WiFI is not working. If the light comes on and you cant connect to the WLAN, then click on the WIFI icon in the system tray. There you will get an option to search WiFi hotspots. When you click on this all the WIFI hotspots in range will be listed. Select the one that is yours and after supplying the WEP key login.
Nov 15, 2009 | Hitachi (ESU64TN001AA) Keyboard
Cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Jun 17, 2009 | Hitachi 51F59 51" HDTV Projection...
MY HIT19WDVBDVD
hi You have to switch it off at the back and switch back on when the hitachi screen saver pops up press the input button once and you will get the input list come up over the configuration screen then select tv mode i struggled for ages to work it out it takes a few goes to get it right but its the only way i could do it as you cant actually exit out of the configuration screen
Apr 01, 2008 | Hitachi C21RF39 21" TV
Hitachi 42PD3000 42 in. Plasma Television Logo
192 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
