Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
I AM ON THE WINDOWS XP AFTER INSTALLING THE DRIVER THE TEST PAGE IS PRINTED BY THE PRINTER BUT ON GIVING COMMAND FOR OTHER PRINTING THE PRINTER DOES NOT PRINT
  • 565 Answers
Got to: start>settings(classic view)>control panel>printers and faxes.
An icon for your printer should be there. Right click the printer icon and select "use as default". While in control panel, you can run the troubleshooter. Sometimes it works. Sometimes the software doesn't install correctly. Uninstall the software from the add/remove software in control panel, then re-install the printer software.
Posted on Feb 03, 2009
How to give test print through command prompt in windows-10.
you can print a test page from the command prompt using this command:
rundll32 printui.dll,PrintUIEntry /k /n “\\atl-ps-01\color-printer”
If you wanted to, you could wrap this command up in a VBScript and execute the test page from there. For more information about running command line tools from within a script take a gander at this classic Tales from the Script column (it’s actually the first Tales ever written
Jul 01, 2016 | Matrix Office Equipment & Supplies
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
I buy a new samsung printer ML-1610 i want to install its drivers so can u tell me how to install and how to get first page print
hello
there have a printer installation CD
please insert it to your computer CD ROM.
it is automatically display some pop up menu you can read and give next command to it.
finally it is automatically display
PRINT TEST PAGE.
give yes command to it
thats over.
Feb 05, 2011 | Samsung ML 1610 Laser Printer
My hp officejet 6210 all in one is instaled under general heading: officejet 6200 series. Result: the printer reacts to command given by laptop windows xp but does not print given text. The paper comes out...
Are you able to print Self test page from printer ( standalone ) or able to make a copy ? if you are able to make copy/print self test page from printer, this issue is with Printer Drivers, You can uninstall and reinstall the software ( download the latest software and drivers from HP website )
If you are not able to make copy/print self test page from printer, it is issue with printer/cartridges... you need to re-align the printer
to clean/align cartridge
On Printer Front panel
Press - Setup Button ( press ok)
Press - Tools ( Press Ok )
Press - Clean Cartridges ( Press OK )
And/Or
Press - Align Cartridges ( Press OK )
Jun 22, 2010 | Office Equipment & Supplies
When i install the printer driver on windows vista is not working
there is a problem on working with software in windows vista. .
try to install the windows XP
Jul 25, 2009 | HP LaserJet P2015 Printer
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
Please help me :(
Hello, you should uninstall the old 'printer' and old drivers, turn off your popup blocker, and reinstall the printer with the new Vista drivers for seres X2310, X2330, X2350.>>> Driver Download <<<
Click the link for a page with several driver options for Vista.
Print this page to a PDF file and save to your desktop for reference until you can print paper documents.
If you do not have a PDF print program, http://www.bullzip.com/ has a FREE (TOTALLY) WARE program for VISTA. I have installed, tested and yes, it works.
You may need to access the Run Command to initiate printing.
How to Access the Run Command in Microsoft Windows Vista Background
The Run command, which was available in the Start menu of Windows 2000 and Windows XP, is not visible in Windows Vista.
Accessing the Run command in Windows Vista
Most keyboards have a Windows key, usually located between the Ctrl and Alt keys. If you hold down the Windows key and press 'R', a Run prompt will appear.
This may be useful if you need to start msconfig in order to limit start items, or msinfo32 to gather system information files (files with a .nfo extension).
Msconfig has added a Tools section. Several common tasks can be managed from here, including Regedit, Event Viewer, System Information, Command Prompt, and Task Manager. To open one of these tasks, highlight the task and click Launch.
Mar 08, 2008 | Office Equipment & Supplies
HP LaserJet 1320 problem
For this you first uninstall any previous Driver. Install the Drivers after restarting your system. After Installing the drivers connect the Printer. Note down now the Driver must be automatically work because HP1320 is a plug n play Printer. If not change the cable used to connect the PC with Printer and if the Printer is auto detected, you will be able to print the Test Page or any other page.
Feb 12, 2008 | HP LaserJet 1320 Printer
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
61 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
