Question about OKI C5200n Laser Printer
Toner warning oki c5600 410:Y toner warning replaced
Is if problem sensor error I am check the toner am see error 543k show met so to fix the problem PL
Posted on Sep 20, 2012
  • 1,602 Answers
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Posted on Feb 03, 2009
3 Suggested Answers
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
  • 159 Answers
SOURCE: OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Posted on Mar 12, 2010
We have recently replaced the toner in our Oki B2400n. The warning light has remained on and everytime we try and print something an alert pops up telling us the toner is empty or low and sometimes will...
Try unplugging it from the power source and then plugging it back in. Have you done everything that the owner's manual tells you to do for this printer?
Jun 14, 2017 | OKI B2400n Laser Printer
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
I have just put new toner cartridges in my Oki C3400 and I am getting the message of "toner sensor error"
look this solution http://my.okidata.com/oki-faq.nsf/FAQCentral/C384D8F74A91CF6E8525765E0065F636?OpenDocument
here the solution for your problem
i hope that it's helpful .... bye
Mar 05, 2010 | OKI C3400n Laser Printer
My laser printer used to click when starting up on the yellow toner now yellow does not print at all.
Replace Y toner cartridge (use oki ones or risk it not working for you, but I have warned you now) it was low (sensor clicking) now it is empty(stop operations)
Chances are that you will then need the other colours too, they all go about same time, but depends on what colours you print, normally black goes first then 3 colours, lights and software should indicate but once it is empty totally all will stop...
You can check visually by removing suspect drum and toner, putting on desk, remove toner cart. from top of drum, inside drum running the width of top surface is a 2 x 15cm wide slot, it needs to have the toner to the brim of this slot (foam edged), there also needs to be toner left in the toner unit itself thats sits on top of this slot.
Cheers
Nov 02, 2009 | OKI C5200n Laser Printer
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
Oki c9600 printer - waste toner box
Sometime the white round spring action mechanism on the printer breaks which causes the toner box warning This mechanism connect to the printer toner box when installed.
Feb 20, 2009 | OKI C9600hdn Laser Printer
OKI Toner
Have very good experience with Uninet Imaging toner for this model. So replace the drum units and try this one. It also have wax particles in its structure. But wax lubricates fuser, not drums...
Jan 14, 2009 | OKI C9300 Led Printer
OKI C5200n Laser Printer Logo
621 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
