Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker not making ice. red light on control panel blinking twice. There is no ice cube in the tray. How ever the black water hose that feeds the tray was frozen solid, so i hit that with a blow dryer. Still waiting to see if that will work.
  • cat_melton Feb 08, 2009
    My icemaker just stop making ice one day and I have not been able to figure out why. I have a red blinking light in the right panel as well.
  • 3 Answers
Took a blow dryer and thawed the black water hose in the freezer.
Posted on Feb 06, 2009
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Ice maker is not getting water to make cubes.
The red light should flash, the most likely suspect is that the inlet tube that carries the water to the ice maker is frozen. If you open the freezer door and hold the swinging door in front of the ice maker up you will see a black rubber tube coming down from the top. If it feels hard it may have an ice block in it.
The best way to clear the block is to turn off the refrigerator or unplug it, warm up the tube with a hair dryer or for quicker unthawing take a turkey baster and squirt hot water into the tube catching the run off with a towel.
It can take quite some time and several cups of hot water to finally clear the ice. Once done it will take about 2 hours for the ice maker to cool back down and start a cycle to test it.
Apr 18, 2010 | Whirlpool GD5SHAX Side by Side...
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
No water to the ice maker
The light (receiver) , should light twice , pause , 2 times , pause , and so on . If you close the left flap (emiter) , the light should go off . This is normal operation for the optics .
Check the black tube (fill tube ) , above the ice maker , to be sure it is not iced inside , blocking water flow . If it is , then the water valve needs to be replaced , due to seeping ( not closing completely ) . Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , and the black tube is clear , replace the water valve . If the ice maker does not dump , and the frozen cubes stay in the ice maker , then replace the ice maker . Also , check the coils under the refrig , to make sure they are clean from dust , lint , pet hair , etc .
Sep 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
190 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
