Question about Sewing Machines
Singer CG590 Timing & Tension Problems
I read a post you answered about someone complaining of tension troubles on their CG590 and you mentioned timing. I have similar problems on my CG590, called the repair shop, they said it was most likely timing and needed cleaning (8 months old and used most every day) so i did just that....repairman said it had lots of lint but the timing was pretty much OK and didn't need to do too much "tune up". So, I get it back home and it is still having tension troubles, but ONLY when I am free motion quilting - drop the feed dogs, put on the darning foot and sew. I would LOVE to know about the timing on a sewing machine so if you could send me that information, and anything else that might benefit me from having to take it back to yet another repairman and pay another $60, I would really really appreciate it! Thanks....Jenn Baker....teambaker1@gmail.com
    Scholar:
  • 34 Answers
Hi, welcome to FixYa. First, if you don't have a manual for your machine, you should purchase one. Click on the link below - it will take you to a site that sells the manual for your machine and might be able to answer your questions.
www.thesewingoutlet.com
Timing adjustments are very precise, different for each machine, and often require a special instrument or tool to set the timing properly. Timing refers to the movement and position of both the needle and bobbin case as the needle moves down into the bobbin to form a stitch. As you probably know, a stitch is formed as the top thread pulls the bobbin thread up, and the bobbin thread pulls the sewing thread down. If your machine can form a stitch when the feed dogs are engaged, it is probably not the timing. If your machine is only a few months old - review your manual carefully. Double-check heck all the recommended settings for free motion - tension, presser foot pressure (if adjustable on your machine), needle position, stitch length and stitch width. Push the lever that lowers your feed dogs into the down position again to make sure it is all the way in the down position (those levers can stick sometimes, especially the first few times you move them). It is really easy to miss a small adjustment that creates havoc if not set properly.
If you don't find a problem with your settings, check back with the repair shop and ask if the offer a warranty on their repair work. If you paid them to clean your machine and adjust the tensions, then you should be able to take it back and have their own work corrected at no charge. When you take the machine back in, bring a swatch of a straight stitch sewn with the feed dogs up (to show the correct tension) and a swatch of your free motion work (to show the problem). Note the tension settings you used on each swatch. If your shop does not offer a warranty on repairs, find a shop that does.
If you and other readers have a minute to rate my answer, it will help me understand the needs of all of you who come to the site for help.
Please feel free to comment if you'd like more information about timing and tension, or if you have other questions. Good luck!
Posted on Feb 05, 2009
The tension adjustment on these machines just plain does not work! I spend more time trying to get it right than I do sewing. And yes, I do raise the presser foot when threading, make sure to get the thread over the hook, etc. It still does no good. A friend of mine also has one and he has given up trying to make it work and plans to sell it. Spent two hours today trying to get it right with no luck. Put the machine on the floor and got my old Singer 457 out of the attic, finished the project in half an hour.
Posted on Jul 27, 2011
Singer cg590 keeps breaking needles
Posted on Jul 25, 2011
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
I have a singer 500/550 .I'm trying too sew a straight stitch ,but I'm having trouble with the tension. What's the best setting? And i can't sew with needle in the middle position. Why
500/550? wow, that an old one. have you check your timing? or the bevel gears?
what type of problems are you having with the sewing. is the thread knotting up on the back side of the fabric? is the thread just breaking? or is it just missing stitches? does the needle hit the bobbin case?
I have a 600 series and I found that if i put the tension around 2 or 3 it sews the best.
too tight the tread breaks, too lose the thread knots up on the back.
I had to change out the bevel gears and have the machine re-time to stop the miss-stitching.
also may want to check your bobbin tension.
May 29, 2015 | Singer Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
How do i fix the timing on my sewing machine
To do it properly you'll need the service manual. You can buy one (it's dowloadable!) here:
http://www.sewnotretail.com/service-manual-for-singer-commercial-grade-cg500-cg550-cg590-sewing-machine/
I was having the same problem and this worked out beautifully. I also adjusted the needle drive shaft height before I reset the timing. While you're at it, check the hook timing belt tension.
Apr 15, 2011 | Singer CG550 Mechanical Sewing Machine
Singer 6105 Tension knob & dial has been manipulated to make proper stitches. Still loops at bottom of fabric. Rechecked bobbin. Cleaned & oiled machine top to bottom. Would I need to order a new...
First make sure that the thread you are using in the bobbin is the same brand and type as in the spool that is threaded. I've read that using different weight threads at the same time can cause tension problems. I have actually had this problem and following this advice it went away. If this doesn't work you may need to have the machine serviced, unless someone else in the forum can advise otherwise. Good luck.
Jan 13, 2011 | Singer Sewing Machines
Sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
Problems with Singer 2732
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jan 02, 2009 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
688 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
