Question about Cisco (WS-X3011) Router
I have a cisco 1721 and it wont accept any input commands. it goes into a error and i cant go any further
  • 5 more comments
  • soldier5492 Feb 03, 2009
    ok when i boot up the router it will not allow me to input anything. I cant send a break or any other commands and get this error
    %SCM-3-SCM_BAD_SPEED: The modem line only supports a speed
    of 115200.
    And I get it about 10 times and then the router stops working
    I have a wic-1am installed in wic 1 slot
    would yo like to see the entire screen shot
    I cant send a break signal to reset anything could it be the homemade console cable it only is pinned on three wires wich should be tx rx and ground
    System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
    TAC Support:http://www.cisco.com/tac
    Copyright (c) 2001 by cisco Systems, Inc.
    C1700 platform with 32768 Kbytes of main memory
    program load complete, entry point: 0x80008000, size: 0x542624
    Self decompressing the image : #################################################
    ################################################## [OK]
    Smart Init is enabled
    smart init is sizing iomem
    ID MEMORY_REQ TYPE
    MainBoard 0X00027A80 1721
    0X000F3BB0 public buffer pools
    0X00211000 public particle pools
    0X0002 0X0000DC00 Card in slot 0
    0X0038 0X00003C00 Card in slot 1
    TOTAL: 0X0033DE30
    If any of the above Memory Requirements are
    "UNKNOWN", you may be using an unsupported
    configuration or there is a software problem and
    system operation may be compromised.
    Allocating additional 1408152 bytes to IO Memory.
    PMem allocated: 28747064 bytes; IOMem allocated: 4807368 bytes
    Restricted Rights Legend
    Use, duplication, or disclosure by the Government is
    subject to restrictions as set forth in subparagraph
    (c) of the Commercial Computer Software - Restricted
    Rights clause at FAR sec. 52.227-19 and subparagraph
    (c) (1) (ii) of the Rights in Technical Data and Computer
    Software clause at DFARS sec. 252.227-7013.
    cisco Systems, Inc.
    170 West Tasman Drive
    San Jose, California 95134-1706
    Cisco Internetwork Operating System Software
    IOS (tm) C1700 Software (C1700-Y-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
    Copyright (c) 1986-2003 by cisco Systems, Inc.
    Compiled Fri 06-Jun-03 20:01 by dchih
    Image text-base: 0x80008120, data-base: 0x809DA464
    cisco 1721 (MPC860P) processor (revision 0x100) with 28073K/4695K bytes of memor
    y.
    Processor board ID FOC07180K2Z (2930095936), with hardware revision 0000
    MPC860P processor: part number 5, mask 2
    Bridging software.
    X.25 software, Version 3.0.0.
    1 FastEthernet/IEEE 802.3 interface(s)
    1 Serial network interface(s)
    1 Serial(sync/async) network interface(s)
    1 terminal line(s)
    32K bytes of non-volatile configuration memory.
    16384K bytes of processor board System flash (Read/Write)
    This command has no effect on this line; use modem AT commands instead
    Press RETURN to get started!
    *Mar 1 00:00:06.703: %SCM-3-SCM_BAD_SPEED: The modem line only supports a speed
    of 115200.
    *Mar 1 00:00:07.355: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
    up
    *Mar 1 00:00:07.355: %LINK-3-UPDOWN: Interface Serial0, changed state to down
    00:00:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed
    state to down
    00:00:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
    to down
    00:00:09: %SYS-5-CONFIG_I: Configured from memory by console
    00:00:10: %LINK-5-CHANGED: Interface Async2, changed state to reset
    00:00:11: %SYS-5-RESTART: System restarted --
    00:00:11: %SNMP-5-COLDSTART: SNMP agent on host 0030-Independence is undergoing
    a cold start
    00:00:13: %LINK-3-UPDOWN: Interface Async2, changed state to down
    00:00:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed
    state to up
    00:00:18: %SCM-3-SCM_BAD_SPEED: The modem line only supports a speed of 115200.
    The entire screen shot it appears the break is set to on but im new to this. I just wanted a router to practice my ccna stuff on and man what a headache
    yes I have tried that to no avail. I have also tried to hard reset it with jumper settings on board inside case. maybee it isnt sending commands because the console cable is home made and isnt right
  • Celenous May 11, 2010
    This is just an initializaion error message and generally doesn't denote a problem just that the wic is rated higher than the router. What WIC do you have installed in the router?
    What specifically are you trying to do and what is the error message you are receiving?
  • 53 Answers
It is possible that the break isn't set. To do this follow this link and take a look at the Reset Router section. Make sure that the break is correctly set and you should get a prompt. You might need to reset the configuration to get this working properly.
Posted on Feb 03, 2009
  • Celenous Feb 03, 2009
    have tried ctrl+break during boot up to try and reset things?
    aye could be can you get another cable? I think you are on the right track. This sounds like a hardware issue or connectivity issue.
Problem with cisco 2513 routers
Check what version of software do you have. Do "dir" command and look at the file name. If it contains "K9" in the name, then it has "crypto" functionality, if it doesn't, then you need to find it (however it will be quite a challenge, as these routers are end-of-life for a decade...)
Good luck,
Mike ' CCNP, CCDP, CCSP, CCVP, etc.
Cisco Compatible Headset Adapters for 7940 7960 etc
Mar 30, 2017 | Cisco Computers & Internet
Hi, when i try to install cisco vpn on my xp machine, it is throwing 1721 error.
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following:
blank.gifMicrosoft Windows NT, 98, and ME.
blank.gifSystem upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.)
blank.gifCombination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x.
blank.gifStart Before Logon.
blank.gifSmartCard authentication.
blank.gifIntegrated firewall
blank.gifInstallShield.
blank.gifAuto Update.
blank.gifTranslated Online Help. Online Help is provided only in English.
blank.gif64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
Nov 04, 2010 | Microsoft Windows XP Professional
I'm trying to install the Cisco VPN client to a Windows 7 (32bit) computer but keep getting a Windows Installer 1721 error. Any advice is much appreciated.
Dear User ,
Follow the Steps below to resolve your problem
1. Click on start and the search bar right next to it , type Cmd 2.As the CMD appears in the search list . Right click on that and Click on Run As Administrator
  1. At the command prompt, type msiexec /unregister , and then press ENTER.
  2. At the command prompt, type msiexec /regserver, and then press ENTER.
  3. At the command prompt, type exit, and then press ENTER to close the command prompt
Try to install it again ,Just in case it fails ,follow the steps below 1.Right click on the VPN setup file and click on Run as admin
Good luck
Thanks and regards Aboobacker S
Sep 28, 2010 | Computers & Internet
Cisco 1721 Router IOS
I can help you with the IOS you need, but Cisco does not list 12.3.x XC, they only have YZ, YG, XR, XK, XG for this router. Email me at thrca@thrca.com for more help.
Aug 30, 2009 | Cisco (WIC-4ESW) 4-Port Ethernet Switch...
Cisco 1721 router serial port not showing any loop.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Nov 15, 2008 | Cisco 2610XM Router
Please advice me as soon as uyou can ..thx
Start troubleshooting the problem by checking the physical layer (Plugs, Jacks, Cables). Replace them with known working equipment.
Once you have traced the line from your Cisco to each other end (through to ISP, and to network switch), then reset your error counters, by restarting the cisco.
Check the ethernet interfaces on the network switch and the Cisco. Make sure they are both set to Autonegotiate or both set to the same settings like 100mbs Full-duplex. If they are not communicating the same way lots of errors will be generated.
Nov 09, 2008 | Computers & Internet
Cisco VPN Client for 32 bit vista
Download the latest version of the Cisco VPN Client. My version is 5.0.03.0530.
You can also try using the Microsoft "MSIZap" utility to ensure a clean uninstall. It is a command-line utility. You will need the original MSI install file from the Cisco VPN client to use MSIZap.
You can download it here: http://msdn.microsoft.com/en-us/library/aa370523.aspx
Sep 22, 2008 | Microsoft Windows Vista Ultimate Edition
Error 1721
What Is Error 1721? This is an error commonly witnessed when you try to uninstall a program using the "Add or Remove Programs" in Microsoft Windows XP. The message itself will read: "Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support personal or package vendor."
Resolution #1: Reregistering the Windows Installer service It is known that if the Microsoft installation engine malfunctions or is internally corrupted, there is a possibly that you will not be able to remove programs that you used the Windows Installer, the service that administers the installation and configuration of programs, to install with. Thus, in the case of error 1721, it is necessary to unregister and then reregister the Windows Installer service to fix the corrupted parts of the engine. This can be accomplished through the Safe Mode by:
  1. Enter your computer in Safe Mode by:
    • Restarting the computer and pressing F8 after the BIOS information is shown
    • Select Safe Mode and Enter
    • Select your computer and Enter
  2. Log on as the local administrator
  3. Open up the command prompt by clicking Start, Run, and then typing cmd.exe and Ok
  4. At the command prompt, first unregister the service by typing msiexec /unregister and then hitting Enter
  5. Reregister the service by typing msiexec /regserver and then hitting Enter
  6. Type Exit to exit the command prompt safely
  7. Try to remove the program once again using Add or Remove Programs
I hope this helps you out. Thanks
Sep 04, 2008 | HP Pavilion dv6000z Notebook
Cisco 1721 router problem
Does the router boot to rommon mode everytime you turn it on?
There are two reasons why the router could be booting to rommon mode
1. There isn't a valid ios image loaded in flash memory
2. The configuration register is set to a number that ends with '0'
Change the configuration register setting to a number that ends in '2'. (i.e. 0x2402)
You do this with the command: confreg 0x2402 <hit enter key> (in rommon mode)
Reboot the router and it will first search for boot system commands in the startup config, if none found it will boot to the first valid ios image in flash memory.
If there isn't a valid ios image in flash memory, the router will continue to boot to rommon.
Apr 12, 2008 | Computers & Internet
Adtran Atlas 550 alternatives
1: Would a Cisco 1720 provide a simple soltution for terminating a T1 to Ethernet 100 Mps I recommend a 1721 2: If this would not be an option, what Cisco box would provide the needed termination/routing I recommend a 1721 3: If a Cisco device could do this would it be necessary to replace them at both locations or could it communicate with the Adtran device. It depends on the topology of how your sites are interconnected to each other. Please describe in greater detail.
Apr 30, 2007 | Adtran Atlas 550 Router
Computers & Internet Logo
454 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
