Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Dishes not clean and leaks sometimes
My dishwasher is a dv62 indesit integrated and is about 7 years old. The problem is it wont clean the dishes properly and it sometimes leaks. I have tried cleaning products for it but to no avail. I've also made sure the salt compartment is regularly filled and even made sure rinse aid' is in. There dosen't seem to be any blockages anywhere. Please advise.
  • Indesit Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Sep 29, 2010
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Rinse aid light
First check in the dispenser is a knob that has an arrow on it see where this points it should only have to be set on one or two normally any higher and you will use more rinse aid if it is on one or two then get a tech to check it it may need to be replaced
Jan 21, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Water pump doesnt stop running
bottom tray under dishwasher holds a cut out switch.this is activated when there is a leak from unit which fills the undertray.
Dec 14, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indersit dishwasher
Dear friend,
ngfam at you service!
If its new your warranty is for 12 months!
YOU NEED SERVICE FOR LIGHTS FLASHING. This is a code signal
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
Nov 22, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dsihwasher Door adjustment
Turn the spring tension screw anti clockwise to reduce the spring strength Regards Engineer
Jul 27, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
My dishwasher is tripping the electric.
Usually time to replace the heating element. The element is sealed inside a metal tube packed with a dry powder to insulate it. If the outer tube leaks (and it only takes a pinhole), the powder gets wet and stops insulating. It only takes a tiny earth leak to take modern trips out. If your dishwasher is one of those where the element is visible in the bottom of the compartment you load the dishes into, replacing it yourself ought to be straightforward. If it's buried in the works, whether you want to tackle it yourself or pay someone else to do it depends on how confident you are. Either way, it shouldn't be catastrophically expensive. A.
Mar 04, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
178 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
