Question about GE WDSR2080D Top Load Washer
GE Mod WDSR2080D5WW won't drain
My top laod washer will not drain, the drain hose tightens up like it is trying but water stays in tub.
Any Ideas on the problem and if it is an easy fix?
Thanks
Thank you!
Posted on Feb 06, 2009
  • GE Master
  • 8,220 Answers
The last one I repaired had a 2 quarters in the pump.
Remove the hoses and inspect the pump for coinage.
Posted on Feb 03, 2009
Washer stopped draining
Something like a sock or small rag is stuck in Pump. That will have to be removed if possible or replace Pump.
Nov 14, 2017 | GE WJSR2070B Top Load Washer
Whirlpool 7mwt9601ww0 top load washer dont open the drain valve
If the tub is full of water you need to empty it. A shop vac with the paper filter removed works good. The drain hose is naturally squishy. Likely there is an object like a sock covering the drain hole in the outer tub. If it's jambed tight enough the back pressure from the pump would collapse the hose. If you remove the hose with water in the tub you will make a huge mess when you remove the sock.
Can't really say more because the mod # you provided isn't correct. Not sure what's wrong, i've tried several combinations but no luck. Perhaps you could recheck it. Make sure it's the model number from the machine.
Feb 05, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Washer Mod# wcsr2090d5ww
It's normal for some water to stand in bottom of outer tub. It shouldn't be visible in the inner tub though.
Oct 31, 2017 | Washing Machines
GE WDSR2080D5WW will not spin.
One of them support rods is probably broken
Apr 01, 2010 | GE WDSR2080D Top Load Washer
We have a GE Profile Harmony washer, it just ran out of warranty in September. It will not drain, it had a message to check the drain hose there might be a clog. We did this the hose was clear. There is...
Along with checking the drain hose, check the drain port from the tub, something may be blocking the drain and no able to get into the tub, or it may be sucked into the pump.
What can happen with a fully loaded machine is, for example, if a small sock happens to be at the top of the load when the spin starts, it can be flung in between the inner perforated drum and the outer. If this gets down to the drain, it may block the drain hole and stay in the drum. It also could get sucked into the drain hose and stay there, or actually get into the pump ... My vote is that it's in the pump, if the pump is humming.
Give it another look.
Dec 14, 2009 | GE WPGT9360EPL Top Load Washer
Old admiral clothes washer leaks at front
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
Drain hose on GE washer clogged with sand
Hi, It is easiest if you have a wet/dry vac and **** the water out of the tub. You can also try and **** the water out of the drain hose and hope the plug is small enough that it breaks lose. The most common place the hose gets plugged is where it narrows after the pump going out the back of the washer.
I hope this helps you.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE WDSR2080D Top Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
GE WDSR2080D Top Load Washer Logo
335 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
