Mesh computer tamper warning
I have just been given a mesh computer.When you switch it on the Bios halts with a warning that the case has been tampered with.There is a small switch on the case cover but the wire doesnt connect to anything on the Motherboard. Does this go to a power connector I wonder or somewhere else on the motherboard which is Athlon socket A.I've entered the bios and changed "halt on" errors to none
Can anyone help
  • ROD GANDY May 11, 2010
    need more information
  • Bob
    Bob May 11, 2010
    What model # Mesh computer do you have?
    Problem Solver:
  • 16 Answers
There is a case intrusion wire that connects from the case to the mobo either you find it or disable it in your can also go to the website to find the connection,I have a whole drawer full of those wires.which should tell you how important case iintrusion is,just dissable it in your bios,unless you have a mobo bandit in the house
Posted on Feb 03, 2009
How can I reset my system when it shows "lid tamper" and then says Master reset required
The lid tamper switch is a small limit-switch inside the computer case.
This lets repair techs know that the lid / cover has been opened since last serviced / purchase.
It could void any warranty if covered.
Usually, going into your BIOS settings at power-up will show a menu option for disabling the tamper feature.
Again, this action may be logged by the software in a hidden system file, readable by tech.
If no warranty, simply disable it.
Dec 19, 2017 | Computers & Internet
I have a iBM t40 2373 Thinkpad when i turn it on i get 2 codes one is 0176 and the other is 0271
The first code is a tamper alarm indicating that the case has been opened and the second code is complaining about the time and date settings. It may just be that the cmos battery is dead and needs replacing because you will also get a tamper warning if the system thinks the battery has been disconnected. A lithium ion battery is good for about 10 years and this computer came out in 2003. Reboot, go into the setup for the bios, set the correct time and date. If this doesn't do it, you need to replace the battery and then configure date/time.
Nov 06, 2016 | IBM ThinkPad T40 2373 Notebook
0912:system security ibm embedded security hardware tamper detected.error system halted
There is a switch in the machine that gtracks if the case has been opened. Alkl you have to do it to run the setup, by entering the BIOS setup routine.
Feb 09, 2015 | IBM Computers & Internet
Chassis intruded fatal error system halted what can i do ro resolve it
Do you have the door on your computer case off? Just put it back on or go through your BIOS and find "halt on chassis intrusion" or something of that nature.
Mar 03, 2014 | ASUS P5V800-MX Motherboard
Warning your chassis has been opened press F1 to continued, what driver am I missing can you help?
your not missing any drivers go into the BIOS under security locate the tamper or chassis reset this will reset set the switch you may even be able to turn it off completely the diver warning is to show the main body has been opened and may have been tampered with.
Oct 06, 2010 | Computers & Internet
Chassis intruded ! fatal error...system halted
Your computer BIOS should have an option to turn this off.
Or you can probably place a jumper on the mother board so the "tamper switch" is always closed.
Consult your motherboard manual for more info.
How to fix chassis intruded ..fatal error..system it my cpu become damage?
It is unlikely that your CPU is damaged
You need to enter the BIOS and turn off chassis intrusion.
It is an option in the bios that is only useful if you have the switch on the computer case that supports it otherwise it will give you the error you see if enabled
Boot enter in config bios
YOu have to clear the tamper switch alarm,. It may be found in the Bios area
May 05, 2009 | ASUS P4PE-BP Motherboard
there is a hardware switch connected to the bios that checks if the chassis has been opened or if it it opened yet.
you must deactivate it in the bios, or perhaps directly on the main board. (but thats risky)
You perhaps also need to close correctly the chassis, in order to access the bios where you will certainly find an option that allows you to deactivate the chassis protection check or whatever else with meaning of a lock or check state about the computer case
Nov 20, 2008 | Computers & Internet
Computers & Internet Logo
513 people viewed this question
David Payne
David Payne
