Question about HP J4680 Office Jet All-In-One Printer
Problem of incompatible cartridge occure in my new J 4580
Sir ,
There is a problem of incompatible cartridge occure in my new J 4580 all in one series.please tell why this problem occure,and how i can slove this problem? My black ink cartridge needed replacing, so I replaced it, but printer is saying my tri-color cartridge is incompatible. This is the original cartridge that came with the printer when I bought and has not needed replacing yet. Why would it tell me that the tri-color cartridge is incompatible when it was the black cartridge I replaced?
  • 7 more comments
  • Anonymous Feb 21, 2009
    J4680 all-in-one - 'Incompatible Print Cartridge : Tri-color.
  • HarrisonDawg Feb 22, 2009
    Exact same problem here, unfortunately I have not resolved the problem. Printer worked fine until I changed the black cartridge with a new HP OEM cartridge. After 4 or 5 print jobs, the incompatable color cartridge error surfaced. The color cartridge is the OEM that came with the printer and there is NO Way it can be out or even low on ink.
  • ali_bongo1 Mar 02, 2009
    Yup. I have the same problem with a J4500. They're both HP print cartridges, and the right ones for the printer. They worked well for a while, now the tri-color one is throwing the Incompatible Cartridge error. No amount of cleaning the cartridge, restarting the printer, etc, will make this error go. What a waste of money that cartridge was.
  • Barbara Smith Mar 06, 2009
    I don't have an opion about the printer yet - I installed it for a customer - but I do have an opinion about HP's customer service. The tri-color cartridge that came with the printer didn't work (incompatible cartridge error). I spent over 7 hours with HP's support in INDIA (good luck understanding them and vice versa - and I am NOT racist - it's just a fact). After telling my story over and over, doing their troubleshooting steps 5 separate times and being on hold and waiting for call backs I finally asked for a supervisor. I told him in no uncertain terms that he WILL replace the cartridge and I won't take any more **** from the unsupportive support idiots. I got a new cartridge. Was it worth it? Not sure yet - customer hasn't really used the printer much yet but I'm going to encourage her to print out a few pix to make sure. What a load of garbage!
  • miltdud Mar 08, 2009
    My ink level indicator went from showing full to a replace tri-color cartridge message. I tried taking the cartridge out and re-inserting it. I tried unplugging the copier for 5 minutes, still I'm having the same error message. The color cartridge is full but the estimated level indication shows a replace cartridge message. No fix found.
  • Anonymous Mar 17, 2009
    brand new c4580, had only ran the test copy; now, the first document i try to print, i get this message...
  • Anonymous May 06, 2009
    I have the 4580 and after changing the black cartridge, I received an incompatible cartridge message for the Tri-Color...all cartridges were ordered online from HP website. E-mailed the company now
  • Anonymous May 09, 2009
    HP J4680 is having the same problem don't get it!!!
    "Incompatible print cartridges: [Tri Color]" message when trying to print pictures/photos.
  • Tricia Scerbo
    Tricia Scerbo May 11, 2010
    Have you checked your manual for any troubleshooting tips? If your manual is inadequate, check the HP website. Is the black cartridge the correct one for your printer? If not, that could be part of the problem.
I had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Posted on Jun 10, 2009
My brand new J 4580 printer that did only 25 pages of printing now suddenly has the same problem with the black cartridge that came with the printer. Looks to me like a real crappy printer. Definitely not close to the quality of my previous 8 years old HP G85. I will definitely not recommend this J 4580 printer to anyone - a waste of money!!!
Posted on Feb 06, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
These types of fatal cartridge errors (i.e. "Refer to device documentation to troubleshoot"), along with the famous "Incompatible Cartridge" error message, typically signifies the HP 901 ink cartridge is suffering from internal electrical (micro-electronic) damage. You can bypass these cartridge error (temporarily in most cases) and run a cartridge health diagnostics check, via the 2 service procedures below:
HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE (please note this is a service test, the printer will attempt to print the tap 41 pattern, whether the cartridges are good or bad):
HP 901 Ink Cartridge Care Tips - Everything you need to know:http://www.youtube.com/watch?v=jTtNj6rN4g4
Posted on Apr 05, 2013
2 Suggested Answers
acdr
  • 1913 Answers
SOURCE: incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
Posted on Dec 25, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Spice 4580 mic jumper
Sir,
Spice m 4580 not working
Nov 08, 2012 | Computers & Internet
My new hp61xl cartridge doesn't work - I get an "incompatible ink cartridge" display
please open the cartridge and check and clean for cotton and re install cartridge insallah solve the problem
May 09, 2012 | HP LaserJet 3050 All-In-One Printer
Spice m-4580 invalid charger problem.
SIR. 4580 MOBIL ME CHARGING INVELID LIKHA AA RAHA HAIN
Sep 05, 2011 | Health & Beauty
Hi, I am using printer HP 4580, and the problem of "missing cartridge" occurs. Please help me out. Thanks
Unplug your printer from both sides. Pull out the cartridge and place it again gently. place it again gently with care in its room. attach again with your computer, restart it you will find it working, INSHALLAH.
Oct 09, 2010 | HP Photosmart C4580 All-in-One InkJet...
Goodafternoon sir, i have small problem in my system cdwriter avaliable. but dos't have nerosoftware&nerocd.how to slove this problem.hardwareperson tell that u go to net & down- load the software.but...
Here are two solutions:
1. Buy a new Nero or Roxio CD burning software at your local shop of IT products.
2. Use a free one.
Well I tried CDBurnerXP. It's very simple, but it does the job very well for me. You can try another one. Choose from the link below:
cddvd-burner/">http://www.makeuseof.com/tag/the-best-free-alternatives-to-nero-cddvd-burner/
Jan 29, 2009 | Computers & Internet
Incompatible cartridge error in j 4580
Dec 25, 2008 | HP OfficeJet J4580 All-In-One Laser...
Sharp AL-1217
It sounds like its either the wrong cartridge or the actual crum chip on the cartridge is faulty
Mar 14, 2008 | Sharp AL-1217 Copier
HP J4680 Office Jet All-In-One Printer Logo
2,283 people viewed this question
Seeker5211
Seeker5211
