Question about Transcend (589307) Media
Pen drive,camera,ext. hard disk not detecting, mouse working fine
I have a Compaq V6307tu laptop.
Everything was running smoothly until day before yesterday when I plugged my external hard disk, it shows that "USB Device not recognized" I tried pen drive and my digital camera but the error was same for all usb ports. But my usb mouse is working fine on all usb ports. I tried reinstalling XP deleting all partition table but the same problem persist. All those devices working fine on my desktop. Pls Help.
Plz creat a new account
Posted on Feb 12, 2009
Asus laptop with Win7 64 bit asks to format WD external drive while other laptops have no issue running it - how come?
you are not swapping from mAC to PC and back , right?
try other USB ports.
many external drives do not run with out an external power pack.
elements, use 4 diffr. 18watt power packs, Are you using the right one?
so plug that in ,first. then plug in USB , w7 must go Ding dong
or the USB is DEAD. (use this as #1 fact to follow)
then put ear to the case of drive, hear it spin?
if not ,there is no power, for SURE.
solve that first.
ok, it spins. (soft whirl\'g sound, do this when new to memorize how GOOD sounds)
for a tests, leave the USB cable , not connected.
let w7 boot to the desktop.
now plug in the USB HDD, cable.
W7 goes, Ding dong.
then see the USB icon in the tray, does it see the drive>?
Y/n?
click on that tray icon, i see USB to ATPI bridge then...
My externals (have many) shows as Z:/external below , bridge....
if not , USB is failing.
yes, ding dong, yes Icon, yes see drive above.!
then go to disk manager, type those 2 words in the run box.
start +run " disk manager"
CP(controlpanel)+computer management +disk management.
does disk manager see this spinning drive.
mine shows,. DISK 2 and is letter coded Z:
if not , the USB port is not working. or the drive is not with power.
if disk manager shows the drive, the assign a letter to said drive
now program manager can see the drive, with this letter Z.
it dont need to be Z , per ce\' but that letter is a nice flag.
step by step.
oops it has green tech, that means it goes to sleep.
make sure you turn that off first. or it may not show up at all.
it\'s so green its , invisible?
wd on their DL page has a spin down utility, use that.
Oct 03, 2013 | Western Digital Elements 2 TB USB 2.0...
MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 03, 2011 | Toshiba Computers & Internet
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
I have a simple tech external hard drive, it was just working yesterday. Now I plug it in and it doesn't show up. some times the blue light flashes fas and other times no blue light just the red. I have...
> showing a time bar
That might have been the "autoplay" function, looking at the files, trying to inventory the files,
to see if it should run a program, or open a program to view photos, or open Windows Media Player to view audio/video content.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 11, 2010 | SimpleTech Signature Mini 160GB External...
Disc drive stopped working
A hard drive can stop working just like any other electronic device when it becomes faulty.
First go into the BIOS configuration and check if the hard disk is detected. If not it could be faulty.
Next re-seat the hard drive, it just may need connecting again to make proper electrical connection.
If it still does not work, then remove the hard drive and plug it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external USB hard drive nor can you open the folders and files then the hard drive is definitely faulty.
To get the laptop functioning again, replace the hard drive, install Windows on the new hard drive together with the laptop's device drivers and your programs.
Dec 11, 2009 | Compaq Presario Notebook
Philips External hard drive not connecting
Try connecting it to a different usb port. plugging out without first stopping the usb device must have the device settings on that port.
Dec 05, 2009 | Computers & Internet
Harddisk is not getting detected
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your
Apr 28, 2009 | HP Compaq Presario CQ60Z Notebook
External hard drive not recognized
I have a WD3200 usb Hard drive. I am looking to partition it. The problem i encountered is when I go to the disk management, the drive shows up as disk one but below it , it says no media. its like the computer knows that there is an external storage device attatched but cannot access it. Also if I try to get into the disk from my computer, it says "insert disk"
Any suggestions?
-Oliver Fernandes
Sep 03, 2008 | Western Digital (WD3200JS) 320 GB Hard...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Transcend (589307) Media Logo
83 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
