Question about Hotpoint Dryers
Hotpoint aquarius tdl30 door dodgy have to bash it to work
The door of my drier has to be bashed to get it to work or hold in certain position then when i let go it stops. have to do this about three times before it will work properly. today nothing is happening at all
  • morna Feb 04, 2009
    will this be expensive to do if i get someone to do it
  • 640 Answers
Replace door switch...onthejob
Posted on Feb 04, 2009
  • onthethejob1
    onthethejob1 Feb 04, 2009
    send me the ,,full model number...after that i will see if i can telk you through doing it your self...onthejob
Tip
How to raise a car door electric window when it is stuck down
Frequently when an older car's electric window stops working the problem is a symptom of a faulty switch or failing motor. Follow this tip to temporarily resume the operation of your electric window if the window has an "auto" feature that rolls the window all the way up or all the way down by holding the button.
Step 1. Locate a rubber mallet or heavy soft object that will not scratch or break an item when you use it.
Step 2. Turn the car to on position so that all accessories are working including the other windows. Hold the button in the up position (if window is stuck down) or in the down position (if window is stuck in up position).
Step 3. In the center of the inside door panel with the door open, strike the door rapidly two or three times as if you were pounding your fist on a table.
If the window starts moving, it will likely continue to work for some time and this tip can be repeated until a permanent repair is required.
on Jul 05, 2010 | Ford Taurus Cars & Trucks
Electric window (driver side) works, but why not the other three?
Power Windows Not Working - Repair Power Windows
www.popularmechanics.com/cars/how-to/a69/1272371/
Another toll-booth, another mile--or at least it seems as if the tollbooths come every ... The most common power window mechanism is pretty basic. ... If the driver's door switch won't open the right rear door, but the switch in the ... direct from the battery positive terminal to the positive side of the motor to see if it comes alive.
Power Windows not working - CarGurus
www.cargurus.com > Questions > Honda > Accord
CarGurusOct 9, 2012 - I have a 2007 Honda Accord the driverside window works but other 3windows dont, but when u hit the master switch on drivers door to try to ...
I can only operate one of three power windows - CarGurus
www.cargurus.com > Questions > Chevrolet > Prizm
CarGurusApr 28, 2013 - Drivers side power window works only. Had a mechanic ... windowsnot working either. ... Already replaced it. all switches showing getting power but don'twork. ... Are you certain that the other three window motors are good?
Why Do My Power Windows Sometimes Stop Working ...
Dec 21, 2015 | Cars & Trucks
Bingo bash, what happened to it? Why has it dissappeared? How do I get it back?
the moment you update any game, it means you loose basically the old files and get them replaced by the new files, so if you really want your old bingo bash, just uninstall the new one that you got through the upadting....then once it is out, download the old one and that should put you back to the same position before you updated anything.
May 31, 2014 | Computers & Internet
Hi I have a Hoover 5005D drier which was going
I USED A PIECE OF CARDBOARD WRAPPED IN DUCK TAPE TO WEDGE BETWEEN THE DOOR AND THE FRAME. IT WORKED FINE FOR THREE YEARS
Aug 05, 2013 | Hoover ACCESS DOOR-U7069/71 - 35121001
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
Bash codes dont work the bash codes used to add users , change user ect dont work what must i do to fix thix? i would be happy if i get asnwer soon because i realy need to make it work to study for my...
i found a tutorial to create a script to make this easier and a tutorial on bash commands
this is a sample menu
When you start the script a menu will appear like this:
### MENU ###
1. ADD USERS
2. Varify Users
3. Delete Users
4. EXIT
http://www.howtoforge.com/how-to-add-linux-system-users-from-a-text-file
and now the BASH tutorial
http://oreilly.com/openbook/debian/book/ch07_01.html
http://www.debianadmin.com/users-and-groups-administration-in-linux.html
Good luck and remember to be sudo when you do these commands
Osogama
Oct 03, 2011 | Canonical Ltd. Ubuntu
Hotpoint aquarius tumbledryer tdl30 not heating
Check that the breaker is fully on by cycling it all the way off, then back on again.
If problem persists, may be an open heating coil.
Dec 20, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Dryers Logo
208 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
