Question about Canon PowerShot G9 Digital Camera
Camera will not turn on with a fully charged battery
I have charged my camera battery and when I place it in the camera, it will not turn on.
  • jim beckwith May 11, 2010
    how old are the batteries
    Sergeant:
    Champion:
  • 373 Answers
From what I read on the canon site they recommend that you get new battery and get good ones and clean contacts
Posted on Feb 07, 2009
NIkon cool pix 5400 will not turn on. Battery is fully charged.
A couple of possibilities. The battery is bad and not accepting a charge. Replace the battery. The battery terminals are dirty. Using cotton swab and some isopropyl alcohol, clean then fully dry the metal contacts on the battery and inside the battery compartment. Before turning it back on, be sure everything is fully dry.
Jun 26, 2016 | Nikon Coolpix 5400 Digital Camera
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
My camera is not working. my camera does not turn on and when it does it turns off
Welcome to FixYa.
For camera's that won't turn on or will turn on but automatically turn off. First thing you need to check if the battery was fully charged.
Second, check if the battery was placed in right direction.
If those two solution was done, You need to removed the battery and re-insert it again.
Also try to install new fully charged battery.
If this issue will continue you need to contact your service center because this might have a camera malfunction.
Feel free to send us your comments or suggestion if this solution was helful.
Thank you for using FixYa.
Apr 07, 2011 | Kodak Easyshare M893 Digital Camera
Wont stay on
I could not find the vpce890 digital camera referenced on sanyo.com.
But, I did find that the battery should be charged by placing in the charger until the light turns green.
Are they Li-ion batteries or other type?
Jul 16, 2010 | Sanyo VPCE890 Digital Camera
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
My lightly used nikon coolpix s570 has developed a power issue. Meaning that with a fully charged battery, the camera won't turn on. sometimes removing and reinserting the battery will get it to turn on....
If you have a second battery, fully charge it and try it. If you do not have a second battery, it make either be a defective battery or a battery that is not properly charging. Try powering on the camera until you get it powered up, either by reinserting the battery or turning it one. Then purposely use the flash and focus until you totally exhaust the battery. Then charge it for the recommended time. Try the battery in the camera once more. Also look into the battery compartment and make sure there is no corrosion. After these actions, the only other thing I could suggest is trying a new battery or sending it in for repair. Usually it is the battery though.
Mar 22, 2010 | Nikon COOLPIX S570 Digital Camera
Canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot SD1000 Digital Camera
How long do you have to charge the battery for Panasonic DMZ-tZ1 camera
Hi Dear,
When you place the battery fro charging in the charger, then when the battery is fully charged. The green light indicator will switch off automatically. Usually it takes 170 mins to charge the battery fully.
Please let us know if this solution was helpful to you, or you need more information on this.
Have a nice day.
Nov 01, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Camera will not function
Try a new battery in the camera, if that does not work, decide if the camera is worth sending to canon to see if they can work out the proublem. Though this is likely to be costly, you maybe better of buying a new camera instead.
Jul 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Batteries brand new rechargables
It could have got wet - they dont like that. Take batteries out - make dry and fully charged Make sure camera if fully dry- put in a warm place to dry slowly- then try
May 11, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Canon PowerShot G9 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
