Question about Microsoft Windows XP Home Edition
''can't load res_dll''
Everytime I turn my computer on it appears a Load dll error window with can't load res_dll error when I click ok it shows up again any suggestions??
  • junkpile3137
    junkpile3137 May 26, 2012
    Followed the fix suggestion. Found no utilities folder AND I no longer have the wireless adapter "stick". It burnt out in less than a week! What do I do now?
  • 86 Answers
If you have or have had a linksys wireless networking device on your computer its software is the cause for the error. You must uninstall the device using its supplied installation cd. Using the windows add/remove software utility does not remove the software. It will remain on your system even if not visible on the installed programs list. Insert the installation cd then exit/cancel out of the installation. Click START then MY COMPUTER then right click on the drive showing the linksys name. Click OPEN then click the "utility" folder. There you will click on the "setup" icon. This will run the uninstall utility and remove all the linksys software from your computer. There is more than one "setup" file at this stage, the one you want will show "setup.exe" as its description as you roll the cursor over it.When its done remove the cd and restart the computer. You can install linksys usb networking devices using the windows new hardware wizard and they will run with no problems.
Posted on May 10, 2009
    Scholar:
  • 152 Answers
Try reinstalling Windows. Apparently, something happened to the file. If you know the syntax for copying a file, you can also try that. (If you want it, let me know. But you must do it in DOS.)
Posted on Feb 03, 2009
Missing user32.dll
User32.dll errors come from issues inside Windows that involve the User32.dll file. This file contains important information regarding graphics details for objects such as dialog boxes. When there is an issue with the file, there will be problems when using other programs that use dialog boxes and other pop-up windows. Normally, a quick Windows update will solve all errors and problems.
Click the "Start" button and then "Run." This will open the "Run" window. Type in "wupdmgr". This will open Windows Update. It will now scan the computer to detect any necessary updates that are available from Microsoft. Turn on automatic updates by clicking "Start" again, followed by "All Programs," then "Windows Update." Select "Change Settings"; then select "Include recommended updates when downloading, installing, or notifying me about updates." Click "OK" and everything will be set. Windows will download the necessary update and install it to correct the User32.dll errors Hope this helps.
Jan 21, 2013 | Acer Aspire One Netbook
Warning "library install.res.1028.dll could not warning
You need to delete your saved game data it got corrupted.
Mar 03, 2011 | Activision X-Men Legends II: Rise Of...
This is what I do on Windows 7 64 bit to make it work.: Minimize the game, even if it freezes, and click cancel on the error box\s that say they can't load whatever file. It will more then likely work then for whatever reason.
Dec 16, 2010 | Activision X-Men Legends II: Rise Of...
Error loading c: progra 1/mywebs 1/bar m3 dll
Morning,
1.Click on Start,Run
2.Type msconfig, click ok.
3. Go to the strartup tab at the top of the window that opened.
4. Look for a startup entry, that is linked to your problem, go through all of them carefully and remove the tic mark in the check box,
5. Restart your PC
6 After the restart, a grey block will popup saying that you've made changes .....
7. Tic the checkbox that says,"do not show this message again"
Problem Solved, if it still pops up ,let me know
Cheers
May 26, 2009 | Microsoft Windows XP Professional
Fatal Error: Loading module SGEDRV.dll failed (Error #126).
Right Click om "My Computer" and select Properties | Advance Tab | Environment Variables.
Select Path Variable in the lower part of the box by clicking on it and add C:\Program Files\Utimaco\Safeguard Easy
Note: To insert ; (semi colon symbol) after the previous path
Thank you
Dion S
May 06, 2009 | Microsoft Windows XP Professional With...
Rundll error
This is most likely a virus. There is no files in Windows with that name. You need to install a good antivirus program and try to get it removed. You can try to get it to stop loading when your computer starts by entering the MSCONFIG utility (Start button -> Run -> type "msconfig" -> click OK). There is a Startup tab on top left. Click it, and it will show you a list of programs that load up when your computer starts. See if you see one corresponding to the 915724.dll or a blank one. Uncheck the box for it, and click Apply and OK on the bottom to accept this change. You will be prompted to restart your computer...do so. When your computer restarts, you will see a new window popup that warns you that something changed. That is because you changed something and is normal. make sure to click the small checkbox on that window so you do not see this warning again.
If you still see the error message, then the virus is a little trickier and you will need antivirus software to remove it. Another option is using System Restore to restore your computer to a time before this virus infected your computer.
Mar 19, 2009 | Microsoft Windows XP Home Edition
CAN PRINT OFF SOME THINGS FROM COMPUTER BUT NOT ALL
To resolve this problem, register the Ole32.dll file.
To do this, follow these steps:
1. Click Start, click Run, type or copy and paste the following command in the Open box, and then click OK:
Regsvr32.exe %Windir%\System32\Ole32.dll
2. In the RegSvr32 dialog box, click OK.
Jan 09, 2009 | Canon PIXMA MP470 All-in-One Printer
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
M3PLUGIN.DLL
Error loading
C:\PROGRA~1\MYWEBS~1\BAR\1.bin\M3PLUGIN.DLL
The specific module could not be found.
please solf this problem
Jul 16, 2008 | Intel Motherboard
Microsoft Windows XP Home Edition Logo
7,466 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
